Results 1 to 7 of 7
Thread: GQ door mirror floppy - how do I tighten it?
    Advanced
    Milang SA
    Hi
    GQ wagon with manual mirrors. The driver side is weak and will blow back in strong gusting wind. How do I go about adjusting it so it stays in place?
    thanks
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    From memory and mines not that great but I'm sure the Maverick we had the mirror had a nut at the bottom where it pivots . But I vaguely remember replacing the drivers side mirror but do remember it was a bugger of a job .
    You need three hands .
    581 Post(s)
    Mine does that too,bloody frustrating!!!
    fishing line from the roo bar to the mirror..
  6. #5
    Is it the type that attaches to the door itself or near the window frame
  7. #6
    Patrol Freak garett's Avatar
    Jan 2015
    south of the boarder
    19 Post(s)
    did this last weeekend. remove mirror from door. under the mirror remove rubber blank. then undo the bolt pull mirror in two. clean the dome shapes that fitt together. put it back together. (remember which way it all goes) make sure the bolt is tight and the spring isn't broken.
  8. The Following User Says Thank You to garett For This Useful Post:
    AB (1st March 2017)
  9. #7
    Advanced
    Milang SA
    Thanks for replies. Yes it is attached by 2 small screws on door.
    Looks like an irritating time coming up.
    cheers
