Results 1 to 3 of 3
Thread: gq/y60 glowplug issues
    heathcote 3523
    Angry gq/y60 glowplug issues
    hi I have a gq 2.8t I've just put new glowplugs in still wont glow on front buzbar no power going to the bar
    tried to locate the relays where to start frustrated archie
    Legendary
    194 Post(s)
    Check the relays on drivers side under the bonnet, in small covered in section behind the main battery. You will need the manual to identify which one is what. Do you get a glow plug symbol on the dash and hear the timer time out? Have you drowned the vehicle recently as you may have an issue with the glow plug controller that is either in the engine bay or in the drivers footwell under the fuse box.
    heathcote 3523
    I can hear the timer timing out light comes on in the dash then starts flashing.
    no it hasn't been drowned I'll check the relays in the morning.thanks
