Results 21 to 30 of 34
Thread: Stretch is having a fuse blowing
    Western suburbs of Melbourne
    11 Post(s)
    as suggested check some/all earth straps.
    check under right rear thats where most ppl cut into loom for trailer plug
    We have triple checked everything from the trailer plug.
    I hope we checked it right and didn't miss anything.
    11 Post(s)
    originally mine was done with scotch loks but after venting
    they soldered all connection then shrink sleeved them as you should
    Lazy buggers eh
    Untaping several suspicious area we found several joins that were done the right way.
  4. #23
    Does it just blow randomly when the head lights are on? or something else is turned on? Is the fuse big enough?
    MEGOMONSTER (23rd February 2017)
  6. #24
    11 Post(s)
    Yes it blows randomly, during the day you really don't know it's blown.
    At night obviously is noticed straight away.
    As dash lights go.
    Has happened once at night when indicating. But hasn't happened since when indicating.
    We also tested the circuit with everything on and only tested 3 amps.
  7. #25
    As dash lights go.
    OK if it blows during the day then it is Not the Parker Light circuit and more likely a dead short mate. Insulation worn through would be my guess.
  8. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    MEGOMONSTER (23rd February 2017), threedogs (2nd March 2017)
  9. #26
    Yep my thoughts exactly...... hood place to look is at the main lot of wires that come through the drivers side bulkhead
  10. The Following User Says Thank You to Clunk For This Useful Post:
  11. #27
    11 Post(s)
    I haven't confirmed if it has blown during times of not have headlights on.
    But yes I suspect worn wiring somewhere.
  12. #28
    Something rings a bell about the hazzard lights when towing will blow fuses
    to way to solve it was to up the fuse rating buy 5 amps
    I think the loom runs along the top of the chassis near the left rear wheel arch.
    Good articulation will see the loom rubbed through, worth a look imo.
    Or pinched by the body work
  13. The Following User Says Thank You to threedogs For This Useful Post:
    MEGOMONSTER (24th February 2017)
  14. #29
    @MEGOMONSTER have you had any luck with this yet??
    what year etc we talking about here???
  15. #30
    11 Post(s)
    2005 3lt
