19th February 2017, 11:17 PM
TB42E cold start/idle issue
Hi everyone this is my first time post looks like a lot of knowledge here hope I have this in the right spot.
I have a 1995 TB42e manual that seems underpowered and doesn't like starting cold or in general for that matter. Start the engine and it will idle very rough and very low like 4-500rpm give it a stab on the throttle straight away idles down to 750 odd idles fine until you turn the A/C on then it idles real low again close to stalling until I give it a stab on the throttle. pickup seems real sluggish with the A/C on or off (In comparison to an identical gq).
It had gas on it but I have pulled it all off adjusted the timing with a timing light to 10 degrees. I have a ecu talk lead and have it up and running on my laptop but I don't know what I'm looking at or understand what all the guages are telling me (ie 02sensor jumps about a fair bit). Also no fault codes? Hope I have explained this well and somone can help identify my drama thanks a lot
19th February 2017 11:17 PM
20th February 2017, 04:43 PM
did you unplug the aac valve before you set the timing? if not your timing will be retarded about 5deg from where it should be.
post a screen shot of your ecu talk reading and ill see if anything looks out of place
20th February 2017, 05:31 PM
Hello and welcome to the forum dont forget to pop over to the intros please
no harm done just some thing the forum asks of us all,
Hopefully your Ecu-talk will give you the answer you seek
Check all the vacuum hoses they may be brittle or just unplugged
20th February 2017, 10:25 PM
I will get a screenshot organised on the weekend. what is the acc exactly I think I did? Thanks
21st February 2017, 08:09 PM
aac is the idle control valve/solenoid at the back of the manifold.
