Results 1 to 6 of 6
Thread: Electric fuel pump for Carby
    Oct 2016
    Wodonga
    G'day guys I have a faulty mechanical pump and the old man suggested that a low psi electric pump will do the job... it's a tb42s
    What psi would work
    You're after a Carter fuel pump 4600 I think,, I'll grab a link for you
    http://www.ebay.com.au/itm/Universal...8AAMXQlbVSGsfa
    @nissannewby would be able to confirm compatibility for you
    North brissy
    Im not sure I can. I dont know what pressure the carb needs to run at on those. Parksy has just replaced a pump but his might be efi.
    Why cant the mechanical one just be replaced?
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    A mate did that years ago. I'll see if I can find out what he used
    >>>tappin from tassie
    Hello from Under Down Under!
    Oct 2016
    Wodonga
    Cheers guys the pumps I was looking at where only 15-30$ is the only reason to change to the electric otherwise I'll just replace the mechanical pump
    Legendary dom14's Avatar
    38 Post(s)
    Quote Originally Posted by Jarvo88 View Post
    What psi would work
    I'm using one of these on my RB30 with the same carby as yours, so it should do the job for you.
    http://www.ebay.com.au/itm/OZ-Kit-El...cAAOSw7aBVCUFf
    Only thing is that I recommend you install it on the engine bay, rather than near the tank at the back.
    The reason is that it makes a pumping noise of the diaphragm inside the pump, and that can be annoying if the noise barrier is not the best under
    the chassis. I guess you can use rubber dampers to mount the pump, but I reckon it's lot easier and cheaper to install the pump in the engine bay.
    I'm moving mine to the engine bay as well. It's bit more work for me with the plumbing, 'cos mine is a redundant pump(which I'm running at the moment anyway). The stock one is inside the tank in RB30 which is a real PITA to get to it when or if they fail.
    Only thing is that when this pump is installed in the engine bay, it's more of a puller than a pusher, so it may take a while to suck petrol into the carby if the vehicle has been left alone for too long.
    I would install it on the engine bay and if it works fine then leave it.
    For any weird reason if it's too weak as puller(which I don't think it will be), you can install it near the tank and use rubber dampers to mute any possible annoying noise.
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
  8. The Following User Says Thank You to dom14 For This Useful Post:
    Jarvo88 (19th March 2017)
