11th February 2017, 10:36 PM
Where is the factory fog light switch located? I've never seen one??
MudRunnerTD (11th February 2017)
11th February 2017 10:36 PM
11th February 2017, 10:39 PM
Moderator
bigguwesty
Ha! Welcome to the late comers! That's actually the point of the thread mate! I have No Idea!
Check out my Toy -->
Rogue Dung Beetle
11th February 2017, 10:42 PM
On the stalk..
MudRunnerTD (12th February 2017)
12th February 2017, 08:04 AM
In my 2010 GU, the fog light switch is integrated into the headlight switch but no sure when that was introduced....
fog
by Bob Howard, on Flickr
GROOVY GUVII
The Following User Says Thank You to clubbyr8 For This Useful Post:
12th February 2017, 10:44 AM
mudski
Im not sure how they should be fitted from factory or ARB but DRLs can be wired in via ignition so they're on when the car is on or via a switch.
I thought that DRLs had to turn off when the headlights were on, so ignition to one side of the relay coil, other side of relay coil via a diode to headlight +ve, or x2 diodes for low & high beam +ve.
Graham
The Following User Says Thank You to GeeYou8 For This Useful Post:
Winnie (12th February 2017)
12th February 2017, 11:26 AM
For my DRL's I used a 5 pole relay. So the DRL's work when the relay is not energised (and the ignition is turned on). The relay operates when the headlights turn on and consequently, the DRL's are turned off. The DRL's still work when the parking lights are on....
GROOVY GUVII
The Following 3 Users Say Thank You to clubbyr8 For This Useful Post:
BigRAWesty (12th February 2017), MudRunnerTD (12th February 2017), Winnie (12th February 2017)
12th February 2017, 10:23 PM
#17
clubbyr8
fog
by
Can't say I've noticed on mine..
We don't have them fitted though.
13th February 2017, 10:41 AM
#18
GROOVY GUVII
13th February 2017, 11:19 AM
#19
GeeYou8
Graham
Maybe so, I was just saying how it can be wired...
13th February 2017, 12:25 PM
#20
maybe those spare fog light plugs only work with
the Ti or GR and not hooked up on the lesser models?? lol
@GeeYou8 is right the DRL should turn off when headlights are on
