Results 11 to 20 of 34
Thread: Engine and drivetrain swap - RD28T to TD42
    193 Post(s)
    Quote Originally Posted by Bigcol View Post
    your gear box should be the same, just the bell housing is different
    you should get 4.11 or 3.9 gears for the diff - (speedo accurate with 4.11 - but better take off and off road with 3.9's just low top
    - or is it the other way around - cannot remember now
    Gearbox is totally different on td42 to rd28. Transfer cases are the same but diffent adapter housing
    Expert SiberianPatrol's Avatar
    Jul 2015
    Siberia
    Gearbox would be swapped out as well
  4. #13
    Patrol Freak Bigcol's Avatar
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    there you go, I was told they were the same
    I didnt know.....................
  5. #14
    Jul 2015
    Siberia
    Anyone have any input on the compression readings I posted earlier? Is the engine worth it or am I looking at a dud?
  6. #15
    192 Post(s)
    Hey mate, yeah bugger hoping it would have checked out pretty well with low Ks and sounds like it runs & starts beutiful. Is it worth doing a another test know sometimes they can be a bit temperamental?
  7. #16
    581 Post(s)
    Hey mate, assuming the engine was hot when you did the test?
  8. #17
    Jul 2015
    Siberia
    Yes. The engine was hot when the test was done - it had just been driven over to the shop. I'm having him go back today and get the valves and lifters adjusted today and then will retest the compression to see if it makes any difference.
  9. #18
    180k is nothing in AUS speak some here have
    motors with 500k on them and still going strong
  10. #19
    Jul 2015
    Siberia
    I'm not worried about the Ks on it. I'm a bit more concerned about the low compression readings. When I bought my RD I had one cylinder with a very low reading and it wound up costing me a complete rebuild within the year. Just want to make sure I don't make the same mistake with this engine.
  11. #20
    Jul 2015
    Siberia
    Yes it was hot/warm. Wasn't it supposed to be?
