6th April 2017, 07:14 PM
#21
BCF in Bundy have concertinaed mattresses for $99 and from memory they`re double mattress size. No idea on the foam thickness though, but looks to ba around 40mm thick and they do feel a bit soft. I don`t know if other BCF stores have the same deal.
6th April 2017 07:14 PM
6th April 2017, 08:04 PM
#22
Dribble Master
Bush Ranger
yeah I've got a similar Oztrail one, not brilliant on their own but I'm a heavy bastard and its only 50mm thick (or so).......... but I like to put it under my 100mm self inflating jobbie for extra comfort during longer stays
Bush Ranger (10th April 2017)
7th April 2017, 03:02 AM
#23
Bitumen Burner
Gotta say, "I love my Clark Rubber, high density foam mattress". In transit, it sits on top of all my plastic boxes, in the pod of my ute.
Rossco
The Following User Says Thank You to DX grunt For This Useful Post:
7th April 2017, 07:11 AM
#24
DX grunt
Rossco
Joisus Grunter, is that a camping pod or a bodouir in a knock shop??? You got a pea under that mattress princess????
7th April 2017, 08:24 AM
#25
@Hodge any update on what you have decided on.??
7th April 2017, 09:40 AM
#26
Bitumen Burner
Touses
Because I'm happily married, it's a camping pod.
I like to call this my mid-life crisis 'Sandman panel van' - of which I used to own one as a young fella. PML.
7th April 2017, 03:35 PM
#27
I just got my 4 "Light Speed" mats refunded from Costco this morning after 2 years because they had developed small leaks.... and then got 4 new ones as replacements!!
The Following User Says Thank You to Bacho86 For This Useful Post:
13th April 2017, 01:34 PM
#28
threedogs
I've had a go at the Megamat suggested by @stevemc181 and they are a winner !
So so comfy nearly as comfy as my ARB swag mattress ( best I've slept on) .
So will be going for those me thinks ...
13th April 2017, 02:54 PM
#29
Adventurist
Hodge
Yep, you won't regret it. I've also removed the little deflation flapper valve in mine so it deflates quicker when I roll it up. This has it's pro's and cons though and makes it a little difficult to release just a small amount of pressure when setting the mattress to exactly how you like it. Make sure you let the mattress breathe unrolled for a day or two before use if it has been packed for a long time or you will need to blow it up a bit more than usual with the included shnozzle pump thing! They take a bit to inflate the first time out of the packet.
The Following User Says Thank You to stevemc181 For This Useful Post:
13th April 2017, 03:22 PM
#30
@Rosscoe your set up looks like its from a Harem scene in Arabian nights,,,,lol
looks very comfy though
