8th February 2017, 08:40 PM
Zd30 crd (limp mode) no power
Hi guys
Now I'm having trouble with my ute
Starts fine runs fine except I seem to be
Going to limp mode (loss of power) and engine light on
It's boosting fine 17psi.
Don't seem to be any leaks, checked oil filter seems
Good. Can't put my finger on it any help or
Ideas would be greatly appreciated.
I have egr blocked completely (both sides)
Egr delete , full nads
Also can't put it on the scanner seems to
Have no power to where it plugs into, any ideas.
8th February 2017 08:40 PM
9th February 2017, 07:59 AM
SUCH IS LIFE
I would pull all that crap you have on there( otherwise called nads) and try again
................on the road
________________________
______ 2017 D-Max _______
9th February 2017, 03:48 PM
Leave the EGR blocked initially, and put all the hoses back to standard, and see what happens....
If it still continues, try putting the EGR back to standard too, as there are some that just like the 10mm Hole in the Blanking Plate to be happy.
10th February 2017, 01:19 PM
I would of backed the boost off a tad to say 15-16psi
dis connecting the battery as you do it,,,, for 1/2hr or so
see how that goes.
10th February 2017, 02:30 PM
I would suspect ECU if it won't scan.
10th February 2017, 02:57 PM
Rsayers
Hi guys
Now I'm having trouble with my ute......
What scanner are you using? The scanner might not be compatible, or even not working.
11th February 2017, 10:44 AM
mudski
Scanner works and has worked on this ute before, I've tested it to see if power
Is getting to the plug and it seems only a few of the pins are actually getting power
I've put 4 different scanners on it with the same result
