Results 1 to 6 of 6
Thread: my DAM! gu reading the ecu ?
    May 2016
    8 Post(s)
    Hi all my gu is testing me ! i now have an engine light on sometimes!!
    2005 Gu 2005 4.2 TI how do I go about reading its mind .
    I have downloaded a manual I am doing somthing wrong . I cant read it its all fragmented like my head ATM .
    461 Post(s)
    Easiest way is via a plug and play ECU reader like a Scan gauge or similar. You can use a jumper wire in the OBDII port and then count the number of flashes it will give off when doing this. The number of flashes means the error code its giving, theres a list somewhere here, or there, which tells you what the codes are.
    Or you can go to Super Cheap Auto, I think its $15 or something and they can plug their machine in for you and tell you what the error code is.
    check/replace your fuel filters
    Expert Mike02Ti's Avatar
    Jun 2016
    Rockingham WA
    4 Post(s)
    Nissan data scan will also pull codes off if you have OBDII reader
    2002 GUIII Ti 4.8
    Details here
    175 Post(s)
    td42ti have a Consult port, not OBDII , and is only read by ECU Talk. No Scangauge etc will work on it.
    Read compatibility here.
    http://www.ecutalk.com/diesel.aspx
  7. The Following 3 Users Say Thank You to Hodge For This Useful Post:
    mudski (6th February 2017), NissanGQ4.2 (6th February 2017), Tip12345 (7th February 2017)
    May 2016
    8 Post(s)
    I have changed the fuel filter . Just to be on the safe side . still looking for the fault
