Results 1 to 10 of 18
Thread: Would GU sway bar disconnects fit a GQ?
    Expert Majestic's Avatar
    Oct 2014
    Central West NSW
    Hi all I am needing to put in sway bars for my GQ Patrol and I came across these sway bar disconnects online:
    http://shop.snakeracing.com.au/gu-pa...r-disconnects/
    I was wondering if they would fit? I like the idea of the pins as it means I don't need to install a cable to connect and disconnect them.
    I've heard that GU and GQ sway bars are interchangeable between the models.
    I have a 2 inch suspension lift and a 2 inch body lift to fit my 35 inch tyres.
    Any advice would be appreciated thanks.
    Owner of 1984 SD33T MK Patrol
    Owner of 1989 TD42 GQ Patrol
    Previous Owner of a 1988 TB42 DA Maverick
    Why not use the right ones? Or am I missing something...
    http://shop.snakeracing.com.au/gq-re...r-disconnects/
    Majestic (3rd February 2017)
    Oct 2014
    Central West NSW
    I missed the GQ ones. However they only seem to have the rear ones. I need front and rear.
    Maybe ring them and ask. I have heard people who have disconnects reckon its a pain in the bum to reconnect them after a muddy and dirty day. I just have two spanners on hand and undo the bolt on one side. Take a few minutes to do....
    Oct 2014
    Central West NSW
    Thanks mate. I think I'll just keep with the standards.
    Advanced abw's Avatar
    Jul 2015
    Sydney, NSW
    On my GU, I run a 2" lift with ARB sway bar extension brackets for the rear (no idea if they fit a GQ) which cost around $17. And the front I just disconnected one side. Seams to flex better with the rear sway bar connected.
    Andrew
    GU3 Patrol, TB48, 33" muddies. front E-locker. 4.11 diff gears. 2.2 metre steel rack. Awning. Steel rear bar. Safari Snorkel. ARB side steps and brush rails. ARB Deluxe bull bar. Winch. 2" lift.
  9. #7
    Quote Originally Posted by Majestic View Post
    If you have a lift the standards will be stretched out to the max. The arm of the sway bar where it bends and joins to the link should be pretty much horizontal. If you have a lift and stock links, my guess the sway bar will be pointing upwards, which means the bar is already stressed just sitting there. You will run a higher chance of failure to the arm or links if left. Just buy the extended link kit which is around half that of the disconnect kit.
  10. #8
    Oct 2014
    Central West NSW
    Yeah I bought the extended ones for my lift. Thanks.
  11. The Following User Says Thank You to Majestic For This Useful Post:
    mudski (5th February 2017)
  12. #9
    Dec 2015
    VIC
    I haven't had any issues reconnecting after a muddy run in the bush. Just needs a bit of a wiggle and jiggle. Just remember to bring a matt to lay on while you do it, or you'll be wearing the mud on your back.
    Also before you buy the front ones, make sure you actually have a front sway bar, since that was an optional feature in the GQs
  13. #10
    Quote Originally Posted by DaveGQ View Post
    It was? AFAIK, all had them. I will look into this.
