Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: My turbo gq shorty
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Welcome aboard mate. Great write up so far. Going to be a beautiful rig. One day I'd love to go down this path....one day.
    >>>tappin from tassie
    Hello from Under Down Under!
  2. The Following User Says Thank You to taslucas For This Useful Post:
    threedogs (2nd February 2017)
    Feb 2017
    Ok
    I decided to fab up my own dump pipe to save paying professional prices and it worked out pretty well in the end. Only thing i would do differently next time is to put a flex joint in the waste gate dump as it was very hard to get all the angles right and its a bit of a pain to fit in the car being one fixed piece.
  5. #13
    Feb 2017
    This is more or less as it sits right now. Its been a costly exercise but the result is awesome. it made 160rwkw on 12psi through the auto, It makes plently of torque and is a blast to drive. Off road especially in low 4 its a beast and will 4 wheel drift if pushed. I am now moving on to stage 2 of this build, which is going to be efi with a long range tank and intercooled. The next few months will be hard work as the list of things needed is growing by the day. I scored myself a nice steel long range tank (145 odd litre) and a haltech sprint 500 in the last few days. I also plan to fit ac while its all in bits again.
    My biggest gripe with it currently is my off road range. Honestly i thought 100 litres of lpg would be ok but its really not. I constantly worry about running out of gas as soon as the needle dips below half and its really thirsty off road. I have proven to myself that its a good combination (tb42 turbo), now i just have to perfect it.
    Turbo is a garrett gt3582r with a .62 rear housing and its the perfect match for the tb42. Makes boost early and has heaps of mid range power. I did get a patrol docta snorkle also as its got to be the best option for an air fiter on a gq that there is.
    Ill update this as i go but it wont be a quick swap over. Im planning to get a custom fuel rail and running xr6t injectors. intank walbro pump and a falcon coil pack ect. I am pretty ocd with my builds and will be doing all the wiring myself so it takes a lot of planning and time to get right.
  6. The Following 2 Users Say Thank You to shortgqturbo For This Useful Post:
    gubigfish (2nd February 2017), taslucas (1st February 2017)
  7. #14
    I have 0ne mtr of 3" stainless flexi pipe here if you need a
    piece more than happy to post you out 300mm to play with ??
  8. #15
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Welcome and nice rig so clean , good to see the pics .
  9. #16
    Aug 2014
    Perth
    10 Post(s)
    What sort of Intercooler are you running on this?
  10. #17
    Feb 2017
    Very generous offer but its the 1.5 inch waste gate pipe that causes me a few dramas each time its going back together. Cheers
  11. #18
    Feb 2017
    Thanks mate, It is getting scratched up being used out in the bush now. The red shows up small tree marks very well
  12. #19
    Feb 2017
    Quote Originally Posted by gubigfish View Post
    As it is there is no intercooler. The next stage will have a front mount setup. It will have to be a thin (50mm) one though to allow some space for the ac and keep the grill.
  13. The Following User Says Thank You to shortgqturbo For This Useful Post:
