27th January 2017, 10:18 PM
#11
This could work Phil :-)
Most of us do have front end space issues between all types of coolers added on. Imagine a slimline fully self mechanical gravity louvre system that once under say 10kmph reverts to a swing closed switch activating a 3,000+ cfm electric blower hidden away :-)
The Following User Says Thank You to MB For This Useful Post:
PeeBee (27th January 2017)
27th January 2017 10:18 PM
27th January 2017, 11:50 PM
#12
Yes was thinking the same, however if the fan is either controlled with a temp switch or is on the entire time, the cooling would be achieved. I am going to explore this a bit.
27th January 2017, 11:51 PM
#13
MB
Good ideas for digestion.
28th January 2017, 06:48 AM
#14
Does the fan have to be in front? The depth of the motor to drive a fan of that size is problematic. Could you run multiple smaller fans?
The Following User Says Thank You to Turtle_au For This Useful Post:
PeeBee (28th January 2017)
28th January 2017, 08:44 AM
#15
Turtle_au
Turtle_au, the fan need to be to the front of the coil as its sandwiched onto the front of the radiator. The oil cooler is circa 200mm x 200mm. If I could get 4 x 100mm fans like the computer cooling fans that would work, but they need to be robust to take the pounding they will take.
4th February 2017, 10:32 PM
#16
Guys, I have decided on a 100mm dia SPAL fan that will push air thru the oil cooler. I ah going this size because i am in the 'dick around phase' of sorting out a water spray setup to cool the aircon, oil cooler and radiator coils, so the water sprays take up perhaps 50% of the face coverage of the oil cooler. I will post the final pics when i have finished - many parallel optimisation paths happening, so could be a couple of week. Appreciate all the fine input and suggestions.
Phil
Reason: cant spell because i is an enginer
