25th January 2017, 11:48 AM
Dawes Settings and Altitude
I live at about 900m above sea level and have my Dawes valve set to about 16 psi. I notice when I go down to the coast that reading will increase to as much as 18 to 19 psi. Now I know that atmospheric pressure is greater at the coast causing the increase and I have to stop and wind back the Dawes about half a turn which gets it back to acceptable levels. I have experienced an over boost engine code on the odd occasion I don't do this. Car performs well at home at my original setting. I also noticed that egts are down a lot further at the coast.
I guess what I am asking is there an easier way to do this or do I have to re tune every trip to lower altitudes.
2008 Patrol 3.0L 2" Raw Nitro Lift, Polyair airbags, Airflow snorkel, Drawers, UHF, Dual battery system and cage scavenged from my Prado Alloy roof basket from the chookyard. Boost and EGT gauges and NADS
1980 MQ Ute (nearly forgot the indestructible farm Ute)
25th January 2017 11:48 AM
25th January 2017, 03:50 PM
18-19 psi is not high for the ZD30 Di motor, Im running 20ish
with no problems.
Leave it as is unless its going into limp mode??
25th January 2017, 05:14 PM
Yeah it did go into limp yesterday. I should have mentioned its a CRD.
26th January 2017, 12:58 PM
Snow Patrol
Maybe back the dawes off a touch to avoid limp mode and see how that goes
have you blocked the EGR?
26th January 2017, 10:26 PM
Time to look up the "how to" maf voltage mod. Then say bye bye to limp mode.
Snow Patrol (27th January 2017)
27th January 2017, 11:28 AM
threedogs
Yep that's all done. Beginning to think now I may have a leak somewhere. Can't seem to get boost back over 15 psi. Will have to investigate. Intercooler was recently replaced btw.
Sent from my HTC_0PJA10 using Tapatalk
27th January 2017, 11:48 AM
Snow Patrol
I take it you replaced it with a fully tigged and tested unit?
Check/or replace your vacuum hoses maybe they are perished
and leaking,
31st January 2017, 03:37 PM
#8
threedogs
and leaking,
Checked all the hoses all good. Nipped up the turbo hose clamps as well. Some were a tiny bit slack. Anyway the news is good. Pressure is back up about 18 psi. Could have been a very small pressure leak coupled with some very hot days keeping the pressure down. Good now though.
The Following 2 Users Say Thank You to Snow Patrol For This Useful Post:
mudski (31st January 2017), threedogs (31st January 2017)
31st January 2017, 04:59 PM
#9
Snow Patrol
If your IC is oily chances are its leaking, you could test it but really they all leak
very early in their life
31st January 2017, 05:10 PM
#10
threedogs
Its a tigged one. I replaced it about 10K ago. But it was leaking.
The Following User Says Thank You to Snow Patrol For This Useful Post:
