Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: tb42e idle rough as guts
    Jan 2015
    Canberra
    If you have changed swapped injectors and the problem is still occurring then it is likely wiring. Check the plug itself, the pins sometimes become unseated, then trace the wiring back to the computer using a multimeter until you find the break in the wiring.
    WARNING: Using a Tow Ball on any Snatch can KILL PEOPLE!
    Feb 2017
    Yes injector hve been swapped. Wiring also have been tested from injector to ECU and all ok. When injector bypassed direct with (-) from battery, its spraying. Looks like no signal coming out from ECU for 1 of the injector. Its a frustations, because looks like the input signal for ECU to trigger the output to injectoris come from Cranks Angle Sensor inside distributors, and I do not know how to test it whether its works or no.
  4. #13
    Advanced brooks's Avatar
    Mar 2011
    Perth WA
    Hi & welcome to you & bernas, i had an issue once with a burnt exhaust valve could also be just sticky. if you hold a piece of paper on the exhaust tail it should blow away constantly, if it sucks back onto the pipe possibly a burnt/sticky valve.
  5. #14
    Feb 2017
    thanks will check it
