Results 1 to 10 of 14
Thread: tb42e idle rough as guts
    Jan 2017
    melbourne
    hey guys new member 1st post
    I drive a tb42e 1993 and it runs rough as guts hot or cold the idle will be like its got a very large cam in it but it does not
    so far iv done the plugs tappets / valves and filters and still running rough know idea what it could be
    still drives fine when ya on the gas though any ideas.
    its got a 4 inch stainless snorkel with a big airbox and a 2.5 inch straight threw zorst with extractors no mufflers
    been like this for over a year but car is a weekender and drivin maybe once every 3 weeks
    Jan 2015
    Canberra
    The first step is to check the error codes on the computer. I think the plug is Nissan Consult, not OBD so you will need to buy/borrow a cable and software. I recently spent about a month troubleshooting rough idling issue, serviced plugs, lead, dissy cap, air and fuel filters, etc. I checked and there were no error codes on the computer, I even used a different fuel pump, changed out air flow meter, throttle position sensor, coil but no luck. In the end it turned out to be a bad EFI computer
    WARNING: Using a Tow Ball on any Snatch can KILL PEOPLE!
    Have you checked all the vacuum hoses they may be perished or become dislodged
    Jan 2017
    melbourne
    Jme gu cheers for that will look into it theres no vacum leaks that i can see and had a fairly good look over and under will look into getting a nissan consult and will see what happens
    Patrol God Dhuck's Avatar
    Nov 2010
    Crap Weather State
    5 Post(s)
    Welcome to the forum mate.
    Hello, and welcome to the forum. Try spraying a bit of WD40 around the inlet manifold and vacuum components with the engine running. If the engine tone changes it means that the engine has sucked the spray in and is burning it as fuel.
    Quote Originally Posted by hummer.03 View Post
    I think some Super Cheap stores can check and erase any errors
    Not sure if ECU talk would suit your Patrol maybe @Bob would be
    able to confirm or deny if ecu talk is suitable.
    Feb 2017
    Hey guys, I came from Indonesiaand this is also my 1st post. The reason I found this forum, excatly the same problem with my tb42e engine. The iddle is fluctuating and I found the injector #6 is not spraying. I have try to switch between them, and clearly its not the injector problem. It must be cable or sensor or ecu itself. Any body got any experience how to fix this? thanks
  10. #9
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    G'day and welcome to the forum mate.
  11. #10
    Feb 2017
    thank you, looking forward if you have any advise or suggestions...
