Results 1 to 4 of 4
Thread: Ford or holden stud pattern.
    192 Post(s)
    Hi guys, just got the old rims of the jayco that i was going to put on fleabay or Gumtree as the tyres are still really good, but don't know what stud pattern they are. Assuming either ford or holden, I know they are very similar. Is there an easy way to tell for sure without taking one down to the tyre shop ?
    This may help
    https://www.alltrailerspares.com.au/...20patterns.pdf
    A 6" steel rule should help, looks like there is 4mm difference approx
    cntr to cntr 67.18mm [ford] compared to 63.45mm [Holden]
  4. The Following 2 Users Say Thank You to threedogs For This Useful Post:
    mudnut (22nd January 2017), Rossco (22nd January 2017)
  5. #3
    192 Post(s)
    Cheers 3D just measured looks like their holden. Easier said than done due to being recessed trying to get a rule in there nice & flat, ended up tracing holes onto sum cardboard, worked a treat ☺.
  6. The Following User Says Thank You to Rossco For This Useful Post:
    threedogs (22nd January 2017)
  7. #4
    Should of suggested a tape measure, but problem solved lol
