23rd January 2017, 12:22 PM
SUCH IS LIFE
Leave it as is and don't fit one
................on the road
________________________
______ 2017 D-Max _______
23rd January 2017 12:22 PM
23rd January 2017, 09:16 PM
All good guy's it's a case of different systems for different vehicles and engine systems
If it is not doing anything other than bringing the light on all good and I would not bother with it and just drive on
Drilling a hole in the plate is no big deal but there are diesel engine's out there where there is no other way around it but to drill a small hole so the engine system can see boost drop, and a increase in inlet temp.
In this case I would just leave it and run with the boost control, see how you go and good luck hope it can work and fix your problem
25th January 2017, 06:59 PM
thanks for the answers everyone will be defiantly investing in manual boost controller then.
10th February 2017, 11:11 PM
Hey all, Have a 2012 3.0 CRD - bought blanking plate (no hole) off eBay and fitted last weekend.
Slightly difference experience to some on this thread. Fitting was pretty straightforward - removed intercooler to get better access (surprised at amount of oily residue in it!). Despite suggestions that I could simply loosen a couple of screws and slide blank plate in, I had to remove 2-off mounting screws from the EGR unit too, so that there was enough movement/separation to get the blanking plate in. Also had to completely remove the 2 outlet screws before I could slide plate in - there was no way I could slide the plate in without doing this due to access restriction... even with slotted cutouts on the screw holes.
Still only took about an hour despite my novice mechanic skills. Happy with the slight low end performance improvement - most noticeably the fuel economy readings on Scangauge - 15-20% better... Can that be right?! Though economy was shockingly bad before. No fault codes yet either.
Will see how it goes towing - that's what prompted me to do it. Was getting 18-20lhk ave towing a 1.5tonne camper... 12-15lkh without!
