Results 1 to 10 of 19
Thread: Air conditioner compressor leak'.
    80 Post(s)
    The air conditioner compressor has started to weep when in use. The sight glass is now showing continuous bubbles but the system still cools well. That to me suggests that the compressor is mechanically ok, except for the seal. The local ref mech reckons the pump is shot and needs replacing.
    My question is this: Once I get the ref mech to test all of the system for leaks other than the seal and it proves sound, is it viable to get him to degas the system so I can remove the pump and fit a new seal seat, shaft seal and O ring, or is it a specialist job?
    Legendary dom14's Avatar
    38 Post(s)
    You can replace all the O rings, but you need degas the system first. Once you've done the O rings and seals, take it to A/C guy to get it dehumidified & regassed.
    Once it's opened to atmosphere, it's important to remove any moisture inside the plumbing with a vacuum pump, which is
    A/C guys job. If you have to take it to A/C guy to degas and regas it, I'm not that sure whether there is any big difference in cost.
    Also, you would have to make two trips to the A/C guy, instead of one.
    Where is it leaking from?
    Can you post a photo?
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
    38 Post(s)
    I'm not sure why he said the pump is shot.
    Is that 'cos pump's internal seals are worn & they are not replaceable?
    If the A/C oil is weeping out, I'm not sure how the gas not leak out in no time!
    Cheetah Outreach
    80 Post(s)
    It is definitely leaking from the front of the compressor shaft but only when it is in use.
    I have been quoted $340 for a unit from Auto Pro. The gas has gone from full to low in only a short time.
    I have asked the receptionist at the ref mechs to get a price on getting them to use a sniffer to make sure there is no more problems, then degassing the unit so I can remove the compressor and seal the system until funds permit me to repair it all.
    Id be evacuating the gas then running a dye through it to pinpoint where it leaks
  7. The Following 2 Users Say Thank You to threedogs For This Useful Post:
    dom14 (13th January 2017), mudnut (12th January 2017)
    38 Post(s)
    $340 for a brand new A/C compressor isn't a bad price, considering the prices I've seen on ebay.
    O rings are dirt cheap, so replacing them throughout the system is a good idea.
    Do the math & find out whether it's cheaper to keep it going the way it is, until you can get it all fixed in one go.
    If you already have ascertained the compressor is fubar, then it might be worth the wait till you have enough funds to fix it all in one go.
    Cheetah Outreach
  9. #7
    80 Post(s)
    That is what a second ref mech said to do. His prices were more reasonable too. The first on rang back and quoted me nearly $900 just for the compressor. OUCH!!! I barely use the thing. I also run the A/C every week or so just to keep it all lubed. I think the trip through the Surrey River and surrounding swamps a while back, may have allowed crap to enter the seals.
  10. #8
    38 Post(s)
    Yeah, but ideally it shouldn't, since the A/C pump is already sealed from front and back.
    I reckon it's just general wear and tear.
    I think, mine's got the same issue, if not similar.
    Refrigerant keeps leaking from somewhere, but mine's using Hychill Minus 30, which is cheap to buy.
    I rarely run mine(and that's one of the problems 'cos I forget to run it at least once a week).
    I've never been a fan of A/C other than it's pretty handy during the winter and rainy days as a windscreen dehumidifier.
    I reckon you should do it all in one go. Making two trips to A/C guy & spending your own time on it can turn out to be more expensive.
    If you can find a way to degas it cheaply or at home then I reckon it's worth a home job, but you still have to take it A/C guy to dehumidify the system and regas it. $350 for a new compressor is good price IMO(with a warranty of course)
    Cheetah Outreach
  11. The Following User Says Thank You to dom14 For This Useful Post:
    mudnut (14th January 2017)
  12. #9
    Patrol Freak garett's Avatar
    Jan 2015
    south of the boarder
    19 Post(s)
    there are o rings for a/c. they differ in composition to the standard o ring you find.
  13. The Following User Says Thank You to garett For This Useful Post:
  14. #10
    @mudnut Ive found air con pump to evacuate the system with all hoses are reasonably priced on Ebay.
    Im like Dom never been a fan of air-con and delay travelling on days 40 plus, anywhere lol
  15. The Following 2 Users Say Thank You to threedogs For This Useful Post:
    dom14 (15th January 2017), mudnut (14th January 2017)
