9th January 2017, 05:02 PM
D I Y fitting 3 inch exhaust
Guys need help
how far of the ground does my patrol have to be to fit the engine pipe without removing the swaybar
cheers
9th January 2017 05:02 PM
9th January 2017, 09:39 PM
without knowing what engine/turbo/exhaust its a bit like asking how longs a piece of string
that said i fitted a heavily modified 3" system from a gu zd30 to my gq tb42e turbo in a couple of hours without lifting the vehicle off the ground exhaust was built in 3 pieces
10th January 2017, 06:46 PM
No need to lift the car up mate, however if yours is ZD30 powered then the OEM dump pipe/DOC (Diesel Oxidation Catalyst) will not come off unless you drop LH side of the sway bar (front).
Regards
The Following 2 Users Say Thank You to Rumcajs For This Useful Post:
OuchOne (5th April 2022), threedogs (27th January 2017)
10th January 2017, 06:58 PM
Patrol Guru
When trying to get the dump of mine to fit the port for the EGT gauge sensor, the exhaust couldn't be got to without unbolting the swaybar properly, soon as this was done it was a much easier job.
10th January 2017, 07:34 PM
I had no issues when fitting a 3" system to my 2009 Crd. Just had the car on stands, so the front wheels were just off the ground. I'm sure I didn't have to get anything out of the way. The big bitch is the exhaust studs... I invented new swear words during fitting on both the 3L and the 4.2L.
The Following User Says Thank You to Hodge For This Useful Post:
11th January 2017, 04:39 PM
thanks guy's
I should have mentioned 2014 zd30 patrol and a redback 3 inch exhaust
11th January 2017, 05:16 PM
driller
thanks guy's
Interested to hear how you go fitting the redback - I'm ready for an exhaust upgrade but still tossing up options (2.75" vs 3") / brands etc
11th January 2017, 11:12 PM
#8
thanks for feedback and will let you know how I go I have a set of ramps and will use them
cheers
The Following 2 Users Say Thank You to driller For This Useful Post:
Bacho86 (12th January 2017), growler2058 (12th January 2017)
26th January 2017, 04:23 PM
#9
Well finally finished
what a bloody job it would be easier if you have small hands and getting the turbo heat shield off was an adventure
as im retired the time frame didn't concern me but if its your only vehicle and needed every day might be a different story.
I had to take the sway bar off on the passenger side and push it back then under the engine pipe as it was different length to OEM one.
I am happy with the difference tho as the car pulls better now.
cheers
The Following 4 Users Say Thank You to driller For This Useful Post:
AB (26th January 2017), Bacho86 (27th January 2017), BigRAWesty (27th January 2017), threedogs (27th January 2017)
27th January 2017, 01:32 PM
#10
driller
cheers
I took the actuator and mount off.
That made the removal of the heat sheild much easier..
And yea sway bar off makes it much easier to install the dump pipe.
