3rd February 2017, 01:19 PM
#41
Adventurist
PBBIZ2
When you say the 'factory axle limits', where are these published or how are they established? I am asking specifically as the VASS engineer who certified my engine conversion, but refused to ratify the GVM Upgrade docs ex WA said he wanted a valid brake test, plus axle load strength data, but could not find it. Just curious, as I am now heading to a different VASS engineer for the GVM upgrade and he hasn't mentioned this. my upgrade is to 3300, not 3500. I am after these values for a 1997 GQ patrol.
Usually you will find this data in the vehicle spec sheets online or in your vehicles user manual if you have it. http://www.nissan.com.au/~/media/Fil...ar%202016.ashx
The GU is rated standard at 1500Kg Front and 1800kg rear. (3300kg total)The engineer should only need an analysis if you are exceeding the factory limits. I'm not sure where you'll find the axle limits for the GQ, I know the GVM is on the vehicle plate, but not sure if the individual axle limits are? I've searched on the Road vehicle decriptor site http://www.rms.nsw.gov.au/rvd-pre1999/index.htm but it does not give the required details other than GVM is 2960kg http://www.rms.nsw.gov.au/rvd-pre199.../pdf/10083.pdf
The Following User Says Thank You to stevemc181 For This Useful Post:
PeeBee (3rd February 2017)
3rd February 2017 01:19 PM
3rd February 2017, 01:44 PM
#42
Thanks Steve, I will see what I can dig up, more out of curiosity now.
3rd February 2017, 02:59 PM
#43
Steve whats the sticker on your door???
3rd February 2017, 03:05 PM
#44
threedogs
It's the Nissan patrol legendary edition sticker . Seen a few around lately.
Sent from S5
threedogs (3rd February 2017)
3rd February 2017, 03:09 PM
#45
Adventurist
Hodge
Sent from S5
Yep, Had to pay extra for that one!
BigRAWesty (5th February 2017)
