29th August 2016, 07:31 PM
Dual Fuel Electronic Ignition - timing retard
From my old dual fuel Range Rover I had salvaged a modern A&R Dual Fuel Electronic Ignition.
But my 'new' 1989 GQ was already fitted with a Piranha Ignition System. ....
Would it be possible to mate the two?
First contacted the maker of the Dual Fuel Ign. in the U.K. - (V8Engines) as friendly as but no conclusive answer.
Then contacted Piranha Australia - same story as friendly as but also no real help.
Eventually bit the bullet and started.
The Piranha appears to be a timing ignition only , not an amplifier. So I could use the output of the Piranha - which normally went to the coil - and connect that to the A&R input where normally the signal from the Lucas Range Rover or points distributor went.
Bingo !! Back in Dual Timing Business.
The A&R unit allows for a generous difference between LPG and Petrol timing.
In brief it works like this:
We tune for optimum LPG timing with the distributor.
Then switch to Petrol and see the timing retarded - this can be fine-tuned on the A&R unit with a small electronic settings screw.
That's all.
Here is a link to the A&R unit :
http://www.v8engines.com/faq-a-and-r.htm
Good Luck !
The Following 2 Users Say Thank You to LandRoverGhost For This Useful Post:
dom14 (15th September 2016), taslucas (10th November 2016)
29th August 2016 07:31 PM
30th August 2016, 08:42 AM
I don't see why it wouldn't work, getting specifics on wiring it up to the Patrol might be your only issue. They are pretty vague about this on their website but I would give it a crack if it was me.
10th November 2016, 10:30 AM
A bit ambitious, how'd you go?
21st November 2016, 11:22 AM
Hi , currently camping so limited computer abuse :-) It went really well, both the old Range Rover timing-retard unit and the Piranha are working flawless together. Also modified the gas carburettor part from Impco to a Blos plus plus OVML dual stage evaporator plus full custom K&N air filter setup. Will describe in detail once home as it works magical. The whole operation turned the car into a real good performing machine. More like what one expects from a 4.2 petrol at top-tuning.
