Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
Thread: GU Drivers side seat belt doesnt retract properly.
    Expert Patrol-Guy's Avatar
    Dec 2013
    NSW
    Hi everyone, the seat belt not retracting properly has annoyed me for a while now. Every time I get out I have to manually feed the belt back in so it doesn't get caught in the door when closing.
    I have done some reasearch on it but most of the advice is to clean the belt and tracks, runners. Done that but didn't fix anything.
    Anyone got any other solutions?
    Paul
    Quote Originally Posted by Patrol-Guy View Post
    Paul
    Hi Paul. Common issue. Nissan sell a teflon pad kit that you wrap around the D ring. It works good. But after a few months its back to normal. I have them on mine. I did see however a chap tighten up the spool on the retractor. He removed the belt from the retractor, and wound the hub up a few turns then put the belt back on. Apparently he see no more issues. I think this was on the P4x4 forum??? I'll see if I can find it.
    Found it...
    http://www.patrol4x4.com/forum/nissa...oblems-260554/
  4. The Following 2 Users Say Thank You to mudski For This Useful Post:
    my third 256 (3rd September 2017), Patrol-Guy (2nd January 2017)
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    Don't waste your time, money and effort. I've tried all the you beaut tricks - and none of them work after a short while. I bought new after market belts from here:
    https://www.seatsafe.com.au/home
    I have had them for years now - and they are perfect.
    Good luck with opening the mechanism and winding up the spring. Buy a new packet of bandaids before you start and wear eye protection!
  6. The Following 3 Users Say Thank You to BillsGU For This Useful Post:
    Patrol-Guy (2nd January 2017), rusty_nail (31st July 2021), threedogs (2nd January 2017)
  7. #4
    X 2 with Bill spend $350 and get some proper belts.
    some clean the belt with hot soapy water, sandpaper the slot
    all short term fixes IMO
  8. The Following User Says Thank You to threedogs For This Useful Post:
  9. #5
    Dec 2013
    NSW
    Thanks but they don't do belts for the 2008 GU6 by the looks. Can only get them from Nissan.
  10. #6
    You wouldn't happen to have the part number they supplied you? Their site doesn't list GU Patrol seat belts.
  11. #7
    Jul 2010
    Thurgoona
    7 Post(s)
    I had the same problem with no part numbers years ago so I rang them. They initially said that they did not carry the ST Patrol belts because their data base said the ST Patrol has pre tensioners on the front belts and the item they stocked which would fit did not have pre tensioners. I pulled my retractors out and they did not have pre tensioners. Its easy to tell as they will have an electrical harness going to them if the have.
    I called them back and ordered the non pre tensioner ones for the Patrol - and as I said - they have worked fine for years.
    Just make sure you get the correct ones if you have a single cab. They are different to the wagon as they sit at a slightly different angle and if you install the wrong ones the belts will be forever locking up when you try to put them on (like they do when you park on a slope and try to put the belt on).
    Give SeatSafe a call. I found them very helpful.
  12. The Following 3 Users Say Thank You to BillsGU For This Useful Post:
    DX grunt (3rd January 2017), mudski (2nd January 2017), Patrol-Guy (3rd January 2017)
  13. #8
    Jul 2010
    Thurgoona
    7 Post(s)
    I have dug through some old tax files and I found the receipt.
    This is for a GU II Wagon.
    Part Number: 1600007 GRY
    Description: Seat Belt 90/90 RH Light Grey
    Price was $241.80 for the pair including delivery to Albury NSW.
    The RH fit both driver and passenger side front. The 90/90 is the angle it is designed to work at. I asked for the light grey colour but I think they did have others.
    @Patrol-Guy
  14. The Following 2 Users Say Thank You to BillsGU For This Useful Post:
    mudski (4th January 2017), Patrol-Guy (5th January 2017)
  15. #9
    Ah remember that too as they dont do belts for my 04 ST
  16. #10
    Jul 2010
    Thurgoona
    7 Post(s)
    Unless yours have pre tensioners I would think that the ones detailed above would fit.
  17. The Following 2 Users Say Thank You to BillsGU For This Useful Post:
    Patrol-Guy (5th January 2017), threedogs (4th January 2017)
