Results 1 to 4 of 4
Thread: Wheel bearing
    Advanced Phill265's Avatar
    Jun 2015
    Wheel bearing
    Hi guys, just a quick one. Other day after a camping trip come home to find my front right wheel bearing was coming lose or was on its way out. I had already purchased a tool to undo the locking nut, so I went about inspecting the issue. When I got to the bearing nuts I founds that I had brought the wrong tool. My patrol has 2 nuts and I had Brought the round tool one that takes the grub screw. I was lucky that the nuts had just came undone so they weren't hard to undo, turns out previous owner hasn't had a tool to undo the nuts so he has used a hammer and cold chisel to tighten both nuts and destroyed the locking tab in the process. Must admit I'm surprised it has taken so long to come undone. The bearings still look fine but I'll be replacing it anyway not sure if he used the right torque settings on his hammer when he did them up. Now this is question, are the round nuts with the grub screw locking plate setup better then the 2 large nuts setup? Is it just as simple as pulling old ones out and putting new set up back in? What do you think?
    Legendary dom14's Avatar
    38 Post(s)
    A picture or two of what you're trying to undo/replace might be of help.
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
    80 Post(s)
    Some have upgraded to the GU style hub locking system.
    Before I knew that was an option, I had already bought the socket for the nuts, so had a local laser cutter make me a heap of locking washers with tabs that worked out to be $2 each.
    Here is some prices to compare and make a choice whether to upgrade.
    http://patrolapart.com.au/category/hub-parts-nuts-tools
  5. The Following User Says Thank You to mudnut For This Useful Post:
    dom14 (28th December 2016)
    Feb 2014
    Southern Tasmania
    I've dealt with both and considering you already bought the tool I would be sticking the GU hub nuts on with the screws. I've been running them for years. They are easier to adjust and a lot less fuss. Also given that Nissan made this change from the GQ to the GU it stands to reason that it is a step in the right direction. What more of an endorsement do you need? My 2 cents.
    -GazQ
