8th April 2017, 09:31 AM
#31
Hodge
Thanks Darren.
What you said makes sense. I also wondered , if I lost a weight or something on the rear left ( which is now on the front left ) , why I didn't get any wobbles or anything before roation. But like you said bringing it to the front will exacerbate the issue. Makes sense.
Also sorry for thread crapping about my issues. This is after all bearing tightening DIY guide.
Sent from my SM-N910G using Tapatalk
PPl dont normally need a balance on the rear wheels.
but most do when buying a set of tyres, so in theory your wobble may
return next rotation as you are again introducing a rear wheel to the front.
8th April 2017 09:31 AM
31st July 2017, 09:42 PM
#32
excellent so easy to follow thanks heaps bobin 51
The Following User Says Thank You to bobin51 For This Useful Post:
MudRunnerTD (30th January 2018)
4th August 2017, 05:53 PM
#33
Hmm , something else I need to check.
4th June 2019, 08:37 AM
#34
Brilliant stuff @MudRunnerTD, this is exactly what I needed to see to learn what to do should I need to tighten these things up on trips etc.
Thanks again.
#35
Thanks again.
2nd October 2019, 05:46 PM
#36
2nd October 2019, 06:38 PM
#37
Take the lowest bolt out of the bottom swivel bearing plate. If there is oil or water it should come out there. I always run a small bead of silicon between the hub and the hub lock to stop water ingress.
The Following 2 Users Say Thank You to mudnut For This Useful Post:
Hodge (2nd October 2019), MudRunnerTD (2nd October 2019)
2nd October 2019, 08:23 PM
#38
Moderator
mudnut
@Hodge yeah take out one of the lower king pin bearing bolts and see if anything drains out. If nothing your good to go.
Check out my Toy -->
Rogue Dung Beetle
2nd October 2019, 08:59 PM
#39
MudRunnerTD
Cheers fellas. Will crack one open tomorrow..
So, let's assume it's oil.
That's the axle seal right?
Which will need a full bearing kit put through?
2nd October 2019, 10:15 PM
#40
Moderator
Hodge
No, it will need a new axle seal. Will and Should ate 2 different words mate 😉
If the seal is gone and you ha e never done a rebuild then it really will make a difference. How many kms has your car done mate?
Rogue Dung Beetle
