Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: H233 GQ diff centers into 4.8 auto wagon IV
    Expert Skitzyrex's Avatar
    Jul 2013
    Hey all, I've looked though for quite some time but can't see if the above will work?
    When searching I've read that the gears were interchangeable but unsure if the 4.8 was the same? And even better if I can just change out the centers.
    Thank you kindly.
    2007 GU ST-S 4.8 Patrol.
    40mm heavy duty springs, Dual batteries,
    140 ltr fuel tank,Custom 60ltr water tank, draws, cargo barrier, bull bar, IPF spotties, UHF.
    330 Post(s)
    The Patrol rear diff comes in 2 sizes. The H233 and the H260. The H260 is a bigger rear centre, it will be detailed n your compliance plate which you have. If you have the H233 rear diff then Any centre will go in that is a H233 except out of a ute which have a different spline count. All the fronts are the same. GQ and GU are interchangeable.
    Jul 2013
    Thank you very much MR
    Can you see which it is from the below. Sorry one more thing, when you say the feints are the same, is that the whole housing or just the center?
    330 Post(s)
    Quote Originally Posted by Skitzyrex View Post
    Yes mate you have a H233 rear diff and your ratios are 3.5s
  6. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    Skitzyrex (17th December 2016)
  7. #5
    330 Post(s)
    You would benefit from fitting 3.9a or even 4.1s depending on your tyre size.
  8. #6
    Jul 2013
    Thank you again MR
  9. #7
    Jul 2013
    I run 33s and picked up complete front and rear housings with 4.11 gears to pick up tomorrow. Got the pair for $300
  10. #8
    North brissy
    The only difference in splines was the 260s I believe. As you had coil and leaf 260 diffs. All 233s are the same.
  11. The Following 2 Users Say Thank You to nissannewby For This Useful Post:
    MudRunnerTD (17th December 2016), Skitzyrex (17th December 2016)
  12. #9
    Jul 2013
    Will both rears be LSD? I know mine is just wasn't sure about the GQ
  13. #10
    North brissy
    Yes unless it has the factory vacuum locker. I believe there were a few rare gqs that had open rears but very rare. 4.11s are cheap and everywhere. Most common ratio for a patrol
  14. The Following User Says Thank You to nissannewby For This Useful Post:
