Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Are Beadlocks legal in Australia?
    After reading the Bridgstone article, which mentions the use of internal beadlocks, I am a little confused. I thought beadlocks were illegal in Australia, but am happy to be proved wrong.
    not over here they're not
  4. The Following User Says Thank You to Clunk For This Useful Post:
    mudnut (14th December 2016)
    Pretty sure the answer is no, most motor x bikes have them std
    Not sure about internal bead locks as well
  6. The Following User Says Thank You to threedogs For This Useful Post:
  7. #4
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Last I heard external ones were illegal and internals were legal but this is a few years ago...so not sure now
    ________________________
    ______ 2017 D-Max _______
  8. The Following User Says Thank You to Maxhead For This Useful Post:
  9. #5
    Nah internals aren't because you have to drill a hole for the second valve so it's a rim modification and I don't know of any rims that come with 2 valve holes.
    As far as I know rims that are manufactured with externals are legal.
  10. The Following 4 Users Say Thank You to Winnie For This Useful Post:
    BigRAWesty (15th December 2016), Maxhead (14th December 2016), mudski (14th December 2016), threedogs (14th December 2016)
  11. #6
    465 Post(s)
    Thats what I am led to believe too. I don't even think an engineer will sign off on drilled rims too. But yeah. Rims made with locks from the factory, are o.k.
  12. #7
    Ah, so even though running the internal beadlock can improve the footprint of the vehicle in soft situations it is illegal if a hole has been drilled. I have had a quick look for rims with the two done at manufacture. Surely it wouldn't be too hard for them to be factory engineered, would it?
  13. #8
    I still think it is state dependant but if if the wheel is manufactured as a bead lock and has adr approval then its legal as said above.
  14. The Following 3 Users Say Thank You to nissannewby For This Useful Post:
    BigRAWesty (15th December 2016), growler2058 (15th December 2016), mudnut (14th December 2016)
  15. #9
    465 Post(s)
    If you find some steelies with the second hole drilled from factory let me know. As I like the idea of internal bead locks.
  16. #10
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    Beadlocks
    www.secondair.com.au
  17. The Following User Says Thank You to Sir Roofy For This Useful Post:
