Results 1 to 8 of 8
Thread: Anyone have one of these fridge / freezer?
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Looks pretty smick, does anyone on here have one?
    http://www.evakool.com/40-litre-drawer-fridge-freezer
  2. The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
    BigRAWesty (17th May 2017)
    174 Post(s)
    I looked at something similar a few years back but ended up buying a bigger upright unit. If the size is right & the seals are good I don't see any problem. Evakool is a reliable brand.
    Issues to consider - Flexibility. This is not a unit intended to be taken in & out of the vehicle at camp, if you want to do that one of the chest portables are better. This is better for 'built in'.
    - Whilst it may not need a fridge slide, the weight & size are probably similar to an equivalent sized chest fridge & slide. Cheaper, & possibly a little lighter, but at the cost of
    flexibility
    - easier to add extra insulation to than a chest unit. However 'traditionally' this style of fridge has been made for truck cabs where they are run for many hours of the day/night
    with the truck motor running so *may* not be particularly well insulated because power consumption is less important that convenience of use?
  5. The Following User Says Thank You to Cuppa For This Useful Post:
    NissanGQ4.2 (18th May 2017)
  6. #3
    Looks good but needs to be built in for sure. You'd really need to give your setup some thought around it but it's static position would really have some advantages too.
  7. The Following User Says Thank You to MudRunnerTD For This Useful Post:
  8. #4
    830mm wide it's big but only 590 mm deep means you could pack behind it.
  9. The Following User Says Thank You to MudRunnerTD For This Useful Post:
  10. #5
    A mate of mine has the Dometic version, I love the idea of it. He still loves it and is glad with his choice.
  11. The Following User Says Thank You to Winnie For This Useful Post:
  12. #6
    Looks like it saves buying a drop down fridgw slide.
    Mainly for truck applications ,a mate has one and loves it
  13. The Following User Says Thank You to threedogs For This Useful Post:
  14. #7
    Jan 2015
    Canberra
    They also make a conventional fridge with a sliding drawer underneath it:
    http://www.evakool.com/evakool-dc70drw-fridge
    WARNING: Using a Tow Ball on any Snatch can KILL PEOPLE!
  15. The Following 2 Users Say Thank You to JME_GU For This Useful Post:
    NissanGQ4.2 (19th May 2017), Yeti's Beast (20th May 2017)
  16. #8
    Expert Yeti's Beast's Avatar
    Aug 2016
    Jimboomba
    4 Post(s)
    That last one is a ripper !
