Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: Wanted 4.6 ratio rear diff gears for h260 diff
  1. #21
    North brissy
    so my understanding is it Must be H260 size and it Must be out of a Leaf sprung rear Ute only. none of the others will fit. I have a mate running the Coil H260 in the rear of his Comp truck and blew it in a race and had a heap of trouble replacing it and found Leafys but they had a different spline count.
    Correct. Leafs have a different bearing setup for the hubs as well over the coils. I believe the coil 233 is 33 spline then leaf 260 35 spline and the coil 260 37 spline. I may have the 260 ones ass about.
  2. The Following User Says Thank You to nissannewby For This Useful Post:
    MudRunnerTD (16th January 2017)
    Expert GU CAMPER's Avatar
    Sheffield Tasmania
    I have ended up getting a new 4.6 crown wheel and pinion from Nissan
    My mechanic has fitted it but now it made a loud bang when put in 4wd after a few hundred metres.
    Does anyone know what could be causing it. Cheers Andy
    NEVER USE A SNATCH STRAP ON A TOW BALL AS DEATH MAY RESULT
    GU 2005 Cab Chassis Ex Telstra POD, Set up for Remote Touring and Play
  5. #23
    North brissy
    Are you certain the front is a 4.6?
  6. #24
    Sheffield Tasmania
    I'm pretty damn sure
    I had the 4.6 diff gears put in a couple years ago. Changed from 4.1
    Will have to double check tho
    The speedo changed the right amount when I changed from 4.1 to 4.6
  7. #25
    North brissy
    By what you describe it sounds like your experiencing wind up of the transfer case. Or there is a problem with one of your locking hubs.
    Are you saying you have had a 4.6 in the front for years or front and rear 4.6 for years? What numbers were stamped into the gears?
  8. #26
    Sheffield Tasmania
    Yeah I had 4.6 in front and rear for a few years. Just had trouble with the rear recently. So I replaced it
    Will have to check numbers
    Might be a problem with locking hub.
    Will check that out
