13th December 2016, 04:03 PM
All good mate, I've actually just found everything I need for a good price.
Thanks heaps though mate. 👍🏻
The Following 2 Users Say Thank You to Pumpdogg For This Useful Post:
jff45 (13th December 2016), threedogs (29th January 2017)
13th December 2016 04:03 PM
29th January 2017, 11:06 AM
That's EXACTLY what mine just did , pulled it out yesterday & it's the same as yours . Doesn't look to have damaged anything else apart from the flex plate , happened at low revs & shut it off straight away .....
The Following User Says Thank You to Sprock For This Useful Post:
29th January 2017, 07:59 PM
I had to tow mine 20-30kms with no gearbox oil. I think that's what damaged the gearbox. Just make sure you have a good look around the spigot on the converter. Mine ripped this out.
16th April 2017, 08:10 PM
Hmm.. seems like it is my turn now. On my way home last night some rumbling from underneath the car, engine slipped, or ran freely for some time, 1-3 seconds, then no propulsion and engine stalled. Starter ran, but did not seem to engangs anything. Strange rumbling from something inside, but no tickover in engine. Removed the starter today. When turning the flexplate, nothing in front of engine moves. Flexplate gone?
17th April 2017, 06:42 AM
Update: I was right in aasuming the plate. Sheared around bolts in center. Gearbox will come down tomorrow.
17th April 2017, 10:59 PM
Is the damage to the convertor OK, or do I have to have it repaired?
18th April 2017, 08:24 AM
#17
With the movement that the TC has been subjected to, I'd be inclined to check inside the oil pump while you have the box out.
It's not difficult, just undo your bellhousing bolts and the pump will probably be stuck to the bellhousing anyway.
They're simple to dismantle as well, no special tools needed. Also check the input shaft for damage.
John
