Results 11 to 20 of 25
Thread: Towbars
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    My towbar has a maximum towing weight (3500kg - which is more than I can legally tow) and a maximum ball weight (350kg). I don't know if they are all like this - but I am guessing they are.
  2. The Following User Says Thank You to BillsGU For This Useful Post:
    dom14 (12th December 2016)
    Legendary dom14's Avatar
    Somewhere inside Victoria, Australia :)
    38 Post(s)
    Quote Originally Posted by Throbbinhood View Post
    I don't have a total weight of the camper, but empty from factory they are supposed to be about 700kg's. I did a bit of basic math on it (70L water tank, 25kg fridge+ 10-15kg food, 40L jerry can's, dual batteries, plus roughly 100-200kg of camping gear). So thinking roughly 1000kg for the camper. I try to keep around 100kg on the towball (so under the 120kg ball limit, but at the 10% downball weight). I just get an axle stand and put it at the tip of the trailer, on a set of home scales to measure (obviously taking the weight off the jockey wheel). When I come home without water, I move a couple of things forward to keep the weight on the towball.
    I think I should be fine for now. The ATM for the trailer is 1500kg anyway so I'm not too keen on carrying much more gear. If I do I'll have to look at changing the towbar anyway.
    Campers heavier than that aren't ideal for RB30 Patrol, especially when going uphill.
    RB30, some 2-3 inch lift auxiliary LPG tanks
    Few more mods on the way
    http://www.worldwildlife.org/species/tiger
    https://www.panthera.org/
    Cheetah Outreach
  5. #13
    Patrol Guru
    Jul 2014
    6 Post(s)
    Quote Originally Posted by dom14 View Post
    Haha uphill and rb30 isn't ideal unless you're in low range anyway. That said, it does do alright. I towed a mates Paj home from the bush on a car trailer the other night. Sat on 95kph no worries. Didn't bother going faster as any faster I could practically see the fuel gauge moving down.
  6. #14
    38 Post(s)
    Yeah, of course.
    You can engage the transfer box by shifting to low range & deal with the steeper hills that way.
    But, how fast can you go that way?
    I meant, RB30 trolls tend to slow down drastically on slight uphills as well. A good NA performance upgrades like finely carby/ignition dyno tuned extractors might be a good thing.
    I find on flat roads, RB30 respond pretty well, on par with TB42s.(or is it even better?)
    Mine's pretty gutless on uphills(especially when once the engine's warmed up) on LPG.
    I think one of the reason is the wrong ignition timing on LPG.
    Once warmed up, on LPG, ignition timing need bit of retardng I think.
    Dual curve ignition unit is the only answer.
    Cheetah Outreach
  7. #15
    Patrol God mudnut's Avatar
    SW Vic.
    80 Post(s)
    I am looking for the official maximum towball weight for a GQ Patrol. The genuine Nissan towbar on the Old Trol has a compliance plate stamped with the maximum tow weight at 2270 kilos, but has no towball weight value. i have spent a bit of time searching, to no avail.
    I can buy a Hayman Reese bar that has a maximum tow ballweight of 350 kilos but that is useless if the Patrol is limited to a paltry 120 kilos (as stated in earlier posts).
    Every van I have looked at have a 130-180 k rating. Are there suspension kits that an be fitted to raise the allowable towball weight?
  8. #16
    109 Post(s)
    I suppose there would be mate (suspension kits), but ultimately it comes down to the load capacity of the cantilevered chassis (unmodified). Suppose rear tower bracing increases that capacity but I don't know of any tested upgrade specs. Have any tower braces been engineered? I don't know.
  9. The Following User Says Thank You to Plasnart For This Useful Post:
    mudnut (5th March 2020)
  10. #17
    SW Vic.
    80 Post(s)
    I have fitted the Superior Engineering bolt-on Tower brace, so that is a start.
  11. #18
    109 Post(s)
    As have I (but different brand), only because they're supposed to protect against chassis cracks from heavy loads. But I took that as a given. Is there any impericle evidence or test results to back this up? Don't get me wrong I'm happy I spent my $$$ but would be interested to see if there's any testing data to back this up. Where is the proof? It has to be out there somewhere. Hopefully?
  12. #19
    SW Vic.
    80 Post(s)
    I had to reset both towers. They had stretched and were nearly hitting the floor. They haven't moved since fitting the braces.
  13. #20
    sunshinecoast
    3 Post(s)
    superior engineering tower braces are engineered and come with paper work to have them certified , whitch might also give you a gvm upgrade for a GU . not sure about a GQ
  14. The Following 2 Users Say Thank You to nipagu7 For This Useful Post:
    mudnut (6th March 2020), Plasnart (6th March 2020)
