Results 1 to 6 of 6
Thread: Projecta system issue
    Nov 2010
    Getting a life...
    38 Post(s)
    I have the Projecta 100 in my GU. Had it for quite a while. But lately its playing up.
    Ive got curcuit breakers between each battery, the breaker between the main battery and the projecta keeps tripping. The AUX battery is r@@ted from being left flat.Is it the projecta or something else ?
    @Yendor, @the evil twin ?
    Last edited by NissanGQ4.2; 28th November 2016 at 05:21 PM. Reason: Fixed tagging for ET :)
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
    194 Post(s)
    A guy at work had a projector 100a unit that was not charging. I opened it up and it had water inside it. Looked nice and dry on the outside. Internals were corroded and shagged. Might pay to have a look. He doesn't do a lot of wet driving, so who knows where the moisture came from.
    katwoman (28th November 2016)
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    What size is the circuit breaker? Any lights flashing on the Projecta? Is the second battery stuffed or just discharged? Have you tried charging it with a 240 volt charger?
    Have you checked the cable between the C/B and Projecta for damage?
  6. The Following User Says Thank You to Yendor For This Useful Post:
  7. #4
    Nov 2010
    Getting a life...
    38 Post(s)
    C/B is 100amp. No lights flashing. Aux battery will not hold charge. Cable seems fine.
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
  8. #5
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    I would replace the battery first and then recheck the Projecta operation.
  9. The Following User Says Thank You to Yendor For This Useful Post:
    katwoman (29th November 2016)
  10. #6
    Nov 2010
    Getting a life...
    38 Post(s)
    Thanks. And as it turns out my altenator is not doing its job properly, that cant help the situation.
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
