20th November 2016, 03:25 PM
UHF Power Adpater
Hi All,
I had a Uniden UHF thats been playing up so replacing it with an ICOM. The power from the uniden was rectangular 3 pin with only 2 in use
This is the ICOM supplied Power lead
Anyone know if you can get adapters so I don't have to replace the existing power cable?
Fish
20th November 2016 03:25 PM
20th November 2016, 04:07 PM
You could try JayCar they have all kinds of plug ends.
its only pos and neg so you could buy a new set
dont forget to fuse it
gubigfish (20th November 2016)
20th November 2016, 04:10 PM
Rotaredom
Just cut the Uniden plug off and join the new plug? Easier than trying to source any type of adapters
20th November 2016, 05:13 PM
Was trying to avoid cutting the supplied cable. Found both types of connector at Jaycar for anyone else looking to do this in future.
The Following User Says Thank You to gubigfish For This Useful Post:
NissanGQ4.2 (20th November 2016)
2nd December 2016, 09:23 AM
The Icom connector is a bit more substantial than the Uniden, the cable looks heavier, it is probably worth the effort to rewire & eliminate any possible faults. Adapters are not a good permanent solution.
If you cut the Uniden connector off you can use the old wire to pull the new one back through the firewall, I would use a relay to switch power on when ignition is on.
Graham
