Results 11 to 20 of 24
Thread: Wheel alignment after rotation???
    Legendary dom14's Avatar
    38 Post(s)
    Quote Originally Posted by VK2FMIA View Post
    Good article on Tire Conicity (misaligned belts) & first tire rotation, worth a read. http://www.agcoauto.com/content/news/p2_articleid/181
    Might be a faulty tire.
    Attachment 70014
    Great article. It's like going to a tyre academy.
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
  2. The Following User Says Thank You to dom14 For This Useful Post:
    VK2FMIA (27th November 2016)
    49 Post(s)
    Going to swap the two fronts ones over and see if it pulls and which way.
  5. #13
    38 Post(s)
    Yep. That's the quickest test you can do. It might sort out the problem.
    Cheetah Outreach
  6. #14
    49 Post(s)
    Swapped and drives just like before.
    We be going back to the tyre place next week.
    Thanks @VK2FMIA for the article.👍
  7. The Following 3 Users Say Thank You to jay see For This Useful Post:
    dom14 (26th November 2016), mudski (26th November 2016), VK2FMIA (27th November 2016)
  8. #15
    Mar 2016
    Nandewar Ranges, NSW
    10 Post(s)
    No worries. Actually learned something myself.
    Sent from my HUAWEI Y300 using Tapatalk
  9. The Following User Says Thank You to VK2FMIA For This Useful Post:
    jay see (27th November 2016)
  10. #16
    49 Post(s)
    Update..
    Went back to the tyre place yesterday and explained what happened. They put it up on the alignment machine and readjusted the toe. Drove it back home and swapped the fronts back over, will monitor over the weekend.
    They said that it could be the tyre, but are checked for size and if it's not within tolerance it doesn't leave the factory. Mine might be just within.
    I told them that I will get back to them next week.
    Must admit that they are very helpful and there was no charge. Was all done within an hour.
  11. #17
    Mar 2016
    10 Post(s)
    Update..
    Thanks for the update. Will be interested to see how it goes.
    Sent from my campfire using smoke signals
  12. The Following User Says Thank You to VK2FMIA For This Useful Post:
    jay see (2nd December 2016)
  13. #18
    38 Post(s)
    Update..
    Yeah, checking wheel alignment is a fairly quick job & adjusting the toe on modern vehicles are fairly easy.
    It can be done it 10-15 minutes on front wheel alignment.
    Most tyre places do the second check for free I reckon, 'cos they would like you to come back.
    If it has fixed the problem, that means you gota free wheel alignment.
    If it hasn't then it must be the tyre.
    I don't think factories check each tyre for manufacturing faults. May be they do occasional one or two out of the production line.
    On some occasions, wheel alignment issues or vehicle dragging to the side on straight flat roads can be caused by structural damage to wheel alignment by accidents(collisions or hitting chassis parts on hard rocks, etc).
    In same cases, after crash repair the pulling to the side on flat road are hard to correct, even though wheel alignment readings on the display(toe, camber, etc) can be corrected to the accepted ranges.
    Keep an eye on the tyre wear pattern. That's more important.
    Ages ago, I drove a Ford that had tyre wear issues that couldn't be fixed without spending a fortune.
    Cheetah Outreach
  14. #19
    49 Post(s)
    Agree with everything you say Dom. Except for the second wheel alignment for free.
    They never did one...
    I got it done when I had the kingpin fitted at a different place, a week after getting the tyres fitted.
    Do that makes them even better👍
  15. #20
    38 Post(s)
    Are you saying the place you went to this time was the place you had the tyres fitted, but didn't do the wheel alignment with them when you had the tyres fitted?!
    I'm guessing you waited one week for the wheel alignment 'cos of the impending kingpin job?
    Cheetah Outreach
