Page 2 of 9 FirstFirst 1234 ... LastLast
Results 11 to 20 of 90
Thread: Barra Turbo (XR6 TURBO CONVERSION) GU PATROL
    Jul 2016
    4 Post(s)
    Hi John
    A friend of mine sènt me this.
    Today i forwarded your responses to my workshop via email so just waiting on a response.
    Another friemd sent me this link
    .heard of this?
    Im wondering if it'd work also?
    http://www.latentsolutions.com/suprastickuv.html
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    There are several solutions for controlling the auto trans depending on your budget but I've never looked into any of them.
    I find the original setup works well for me and it cost nothing as it was all in place anyway.
    If it were me, I'd spend the money on getting the trans beefed up before spending up on fancy controllers..
    John
  4. #13
    Jul 2016
    4 Post(s)
    So, a bit of an update on where I'm at, at the moment with the engine conversion, I was speaking to a friend of mine who asked an engineer in regards to what I am doing and he has come back with the following info, If any of you are thinking of doing a conversion (regardless of engine) refer to this below.
    So , if your new engine weighs less than the original you won't need a swerve test as it will not affect the weight of the vehicle due to the barra turbo engine weighing in less than the original 4.5 petrol donk. Its not the power , speed is speed, its how quickly you can stop the speed you're going, and if your new engine is heavier than the original you have a problem.
    Also since that is cleared that I won't be needing a swerve test, I also don't need a torsion test, Apparently torsion test is a test used to see if the chassis can handle the extra power slash torque, So to know if your new engine that you're planning to use in your conversion passes this you use the below info.
    Make and model of car: find the highest torque output engine that was placed in these vehicles (in my case the TB4.8 which produced 420nm of torque from factory, add 20% and if the new engine you're using is producing less torque than that figure then you're laughing.
    So 4.8 patrol 420nm x20% = 504nm
    BF 480nm which means I am within my requirements.
    This way now I just gotta worry about the other engineering things like engine mounts etc and if all is honky dory then engineering shouldn't be a problem.
    No news yet on the bell housing either… I guess Im currently a sitting duck!
  5. #14
    Jul 2016
    4 Post(s)
    Hi John , Yeah I told my tune shop thats doing the conversion that i will look into strengthening the auto down the track when it blows, his response to me was "What, on the third dyne run?"
  6. #15
    Jul 2016
    4 Post(s)
    Update on this in point form cos 1 hand is in plaster
    Engine is at workshop
    Fellow bell housing has arrived
    Tranny has been sent to be fully rebuilt
    Will be fully manualised auto with bm ratchet pro shifter
    When's auto comes back buying 1000cc injectors
    Plenum chamber
    300x600x76mm cooler
    Now expecting 350rwkw to 380rwkw
    I can't wait!
  7. The Following 3 Users Say Thank You to Baby Daddy For This Useful Post:
    BigRAWesty (6th May 2017), gubigfish (6th May 2017), MB (6th May 2017)
  8. #16
    Sweet as. How much has it cost so far?
  9. #17
    Jul 2016
    4 Post(s)
    3500 on engine , ecu , loom , thermos
    3000 for full rebuilt re4 auto
    1200 for upgraded converter
    750 dellow bell housing
    Then got cooler injectors, Labour, custom input shaft,
    Cooler piping,
    Custom loom
    Engine mounts, tune, install , custom fab work for air box and snorkel,
    Custom exhaust engineering etc..
    Looking at about 20k
  10. The Following User Says Thank You to Baby Daddy For This Useful Post:
    mudnut (6th June 2017)
  11. #18
    Jul 2016
    4 Post(s)
    Hi guys , been a while since I've posted here as I have been documenting the build on 4x4 earth.
    I Am going to try and attempt to keep the posts here more frequent in the hope that some may find the input useful.
    So at the moment my RE4 tranny has been extensively modified and fully rebuilt from the ground up.
    It was built to the same spec as one he sent off to NSW for an xr6 turbo (yes they use them in xr6's too as an upgrade so they must be good). That tranny is currently pulling 9.90s consistently down the quarter so I should be ok running it in my patrol...
    We are now waiting for the torque converter to be built which would be done some time this week.
    Once that's done it's will be married with the tranny , vellhousings etc and sent back off to my tune shop...
    Here are some photos of the tranny being built
  12. The Following 2 Users Say Thank You to Baby Daddy For This Useful Post:
    AB (13th August 2017), Avo (14th August 2017)
  13. #19
    Jul 2016
    4 Post(s)
  14. #20
    Jul 2016
    4 Post(s)
