Results 1 to 10 of 12
Thread: Water to Air Intercooler damages motor.
Hybrid View
    175 Post(s)
    Drove past a Patrol ute this morning with steam gushing out, bloke looking under the hood. Pulled up and reversed back to see if I can help.
    Oily steam crap coming out of filler cap, exhaust and steam gushing out through air filter box. My self and the owner clueless as to what happened but clearly motor was in a bit of bother.
    Stayed theretill towie came to pick him up. Left my number with him as I was curious whats gone wrong. Just spoke to him before and turns out a split in the water to air cooler sent coolant into the motor and it was game over right there and then. Bugger!
  2. The Following 5 Users Say Thank You to Hodge For This Useful Post:
    macca (22nd November 2016), MudRunnerTD (22nd November 2016), mudski (22nd November 2016), Sir Roofy (22nd November 2016), threedogs (22nd November 2016)
    Oct 2010
    Old Bar, NSW
    13 Post(s)
    Bugger, not something that you would think of when buying a W2A cooler.
    Macca
    My IC was pressure tested to 60psi why not a W2a one???
    might of been a homemade job who knows???
    Oct 2010
    Old Bar, NSW
    13 Post(s)
    What is the pressure in a W2A system?
    Macca
  6. The Following User Says Thank You to macca For This Useful Post:
    The ones I checked on Ebay never gave a pressure rating.
    Its was only water circulating via a pump
  8. The Following User Says Thank You to threedogs For This Useful Post:
  9. #6
    North brissy
    Stuff all. Less or similar to your cooling system.
  10. The Following User Says Thank You to nissannewby For This Useful Post:
  11. #7
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    If it was an internal split from too much pressure wouldn't it more likely be the air pressure causing it rather than the water pressure? Just like when a regular air to air intercooler splits
    >>>tappin from tassie
    Hello from Under Down Under!
  12. #8
    North brissy
    >>>tappin from tassie
    It would have to be a lot of pressure to split it. These things wil run at 30+ psi without a problem. Poor mounting or as ben-e has stated poor system maintenance resulting in electrolysis.
  13. #9
    Patrol Guru 89gqpatrol4x4's Avatar
    Brassall
    Have just asked about people's thoughts on these on another forum. Looks like i may have made my mind up! Poor bloke that's something I can not in any shape financially afford to have happen. Hope it's not to costly got him. I'll go the front mount me thinks.
  14. #10
    North brissy
    There has got to me more to this than the info given here. These are just like any other heat exchanger. You have one attached to the side of your engine that is used for oil temperature control. They are generally very reliable devices.
