Page 6 of 6 FirstFirst ... 456
Results 51 to 59 of 59
Thread: Chester's 88 GQ
  1. #51
    @ Chester no over heating issues ??
    X 2 cant beat the sound of an angry Chev belting up a hill
    Did you retain air con ?
    Expert chester's Avatar
    Apr 2011
    No mate not so far,i fitted a mechanical temp gauge in it,it would go up to 100 then went down straight away and sat on about 90 which was good but I didn't like the way it would spike to 100 so I changed the thermostat and it now spikes to 88 and sits on about 80-85 even in the bush .
    I did have all the air con on to start with put I pulled it all out.
    A GOOD MATE WILL BAIL YOU OUT OF JAIL, A BEST MATE WILL BE SITTING NEXT TO YOU SAYING YEP WE F**KED UP
  4. #53
    Apr 2011
    Couple of photo's with the new boots.
  5. #54
    Apr 2011
    Brought a little ute to run to work in so the patrol is no longer my daily drive . So it now will sit in the shed and only come out for bush trips, let the mods start LOL.
  6. The Following 2 Users Say Thank You to chester For This Useful Post:
    Bloodyaussie (9th June 2014), Winnie (9th June 2014)
  7. #55
    Quote Originally Posted by chester View Post
    Best thing I ever did to my Patrol was get another car... Lol
  8. #56
    Gold Coast
    I just bought an 88 myself, had a cracked head so I got it pretty cheap and fixed it myself.
    Stills needs a bit of work, come into some carby trouble.
    Not as nice as yours but you have given me some good ideas.
    Thanks mate
  9. The Following User Says Thank You to Petrolling For This Useful Post:
    chester (25th August 2014)
  10. #57
    Apr 2011
    Well I have some bad news, went for a snow drive on sunday got stuck on a hill and managed to get up. Got out for a smoke while waiting for the other's the patrol was sitting there idling nicely when it stopped, just stalled.
    Fair enough I thought hit the key nothing, was like it had a flat battery,thought it might be in a dead spot turned the crank by hand and BANG she locked up, turned the crank the other way done a full 360 then BANG locked up again.
    So after getting towed home through the snow which was a bit hairy LOL dropped the sump off and no metal was found. After a few more test's decided to rip a head off and found a chunk of metal in number 8 cyl.
    Result stuffed piston and rings and that's it. Lucky it happenend at idle and not under rev's other wise it would have 10 times worse.
  11. The Following 2 Users Say Thank You to chester For This Useful Post:
    Bloodyaussie (16th July 2014), Winnie (16th July 2014)
  12. #58
    Apr 2011
    Well well well turns out I may have been abit heavy on the loud pedal, bit more work then just a pistion and rings LOL
  13. #59
    You hoon. Haha, what is the verdict?
