Page 3 of 64 FirstFirst 123451353 ... LastLast
Results 21 to 30 of 634
Thread: Turbo Upgrades for the GUIV TD42Ti
    175 Post(s)
    @Hodge do you have a bigger Turbo on yours mate?
    Hey Daz.
    No mate. The only upgrades I have are the CC intercooler/scoop and a JPC high flow water pump all with a good tune.
    But,as per my previous post I am watching the thread with much interest!
    Also, I will add, the CC intercooler tamed the EGT's big time and gained a couple of ponies with it too. Pricey, but good investment.
    Have you also considered a bigger air intake ?
  2. The Following User Says Thank You to Hodge For This Useful Post:
    MudRunnerTD (1st November 2016)
    Hey Daz.
    Hi mate, no I haven't considered intake mods really. I have a billet air box lid with a cobra head which I got off @Stropp when he upgraded his airbox. Stropp did you do your airbox upgrade as a stand alone mod? Did you notice a huge change? What snorkel have you got feeding it?
    Eric what sort of power did you make with your tune?
  5. #23
    I think a bit over 2k for the BW Dazz plus a couple or more hundred for t5 adaptor, larger actuator, short bracket and other goodies so more on the 2.5k mark.
    Can you help me with a parts list and where to get all that mate. When the time comes I need to not loose any time parked up as it's the Daily for Naomi and I can afford to not have everything I need to bolt up and go.
  6. #24
    Patrol Guru Kimbo63's Avatar
    Dec 2015
    Perth WA
    5 Post(s)
    PM already sent for 4.3s possible off mate Daz!
    Hi daz my diff / diff gears are of my 2.8 litre and are 4.625:1 the 4.375:1 gears you are after are from the 3 litre autos
    Cheers Kimbo
  7. The Following User Says Thank You to Kimbo63 For This Useful Post:
  8. #25
    Quote Originally Posted by Kimbo63 View Post
    Cheers Kimbo
    Thanks Kimbo. You should get good coin for the 4.6s mate, everyone wants them.
  9. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    Kimbo63 (1st November 2016)
  10. #26
    581 Post(s)
    Sure no probs
  11. #27
    175 Post(s)
    I went up from 75kW to about 100kW with just a tune after fitting a 3" exhaust.
    Then after fitting the CC intercooler they easily reached 115-120kW, but apparently the car was gasping for air at that stage or beyond.
    The standard HT18 was at its peak range so they suggested if I want more, I'd need a better turbo and/or open up the air intake.
    The IP was also a limiting factor.
  12. The Following User Says Thank You to Hodge For This Useful Post:
  13. #28
    When you do this work Darren I would suggest to take it to diesel tech for a tune up. I don't think the tune you had was very good.
  14. The Following User Says Thank You to Winnie For This Useful Post:
  15. #29
    581 Post(s)
  16. The Following 2 Users Say Thank You to AB For This Useful Post:
    Hodge (1st November 2016), MudRunnerTD (1st November 2016)
  17. #30
    581 Post(s)
    Just make sure you get 38mm bolt spacing for the oil drain and gasket.
    I think I also have a set of M8 x 1.25 studs too.
    Then Pirtek is your new friend in plumbing it up and I can help you there too with exact fittings and lengths, etc.
  18. The Following User Says Thank You to AB For This Useful Post:
