Page 42 of 64 FirstFirst ... 32404142434452 ... LastLast
Results 411 to 420 of 634
Thread: Turbo Upgrades for the GUIV TD42Ti
  1. #411
    579 Post(s)
    Hey Kat how much would you want to spend?
    for an extreme budget I would try and find a second hand ht18 turbo that someone is upgrading theirs.
    Standard turbo for td42 and turbo manifold.
    Putting an intercooler in would be ideal, you might even find a complete turbo and IC set up like this one below...
    Td42 Gu turbo and intercooler kit on Gumtree http://www.gumtree.com.au/s-ad/11872...utm_source=sms
  2. The Following User Says Thank You to AB For This Useful Post:
    katwoman (26th June 2018)
    Nov 2010
    Getting a life...
    38 Post(s)
    Something like that would do. No point spending big $$ on something that I won’t be allowed to keep. thx AB
    What do I look at 2nd hand to make sure it’s not stuffed ?
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
  5. #413
    579 Post(s)
    Hopefully Matty can help here but I would look for shaft play of the turbine, condition of fins on turbine making sure they don't have chips out of them and the shaft doesn't move side to side too much.
    Check the inlet where the fins are to see if any scratches on wall and check if any signs of oil leakage around turbo compressor housing.
    Check for cracks on IC and just general condition checks, etc.
  6. The Following User Says Thank You to AB For This Useful Post:
  7. #414
    324 Post(s)
    Just ordered a 12mm UFI 250HP pump for the GUIV....
  8. The Following 3 Users Say Thank You to MudRunnerTD For This Useful Post:
    Hodge (27th June 2018), mudski (27th June 2018), Rossco (27th June 2018)
  9. #415
    460 Post(s)
    Look out! .........
    MudRunnerTD (27th June 2018)
  11. #416
    174 Post(s)
    Far out Dazza now you'll be smashing even more diffs with that power ...
    Congrats !
    I've really gotta do what you've done to my gu4 someday.
  12. The Following User Says Thank You to Hodge For This Useful Post:
  13. #417
    324 Post(s)
    Pump and front mount going on this weekend.
    Just booked some Dyno time at Geelong Performance Diesel for 30th July so a week untuned will be required.
    http://geelongperformancediesel.com.au/
  14. The Following 3 Users Say Thank You to MudRunnerTD For This Useful Post:
    0-TJ-0 (15th January 2019), BigRAWesty (21st July 2018), Cremulator (20th July 2018)
  15. #418
    324 Post(s)
    So i have not been back here but damn have i been busy.
    Had a couple of huge weekends including hosting Matty and Rossco for 12 hours or more to fit this UFI 12mm pump.
    I took Rosscos advice and bit the bullet and decided to do the front mount cooler the same weekend cause, well, it won't take long right!!!!! Damn!!!
    Photo bomb
    Off with the front bar
    This was in the way as was the AC fan and PS Cooler
    Made a mount for the IC. Pretty pleased
    Removed the intake pipe as it needed to be rotated anyway to point the other way.
    I blocked the EGR about 8 years ago. Check this out!! I took the opportunity to fully remove it (cause you know, i had time!!)
    Fan off. Radiator out. PS pump removed. Front cover to be removed.
    Fuel rail off as i changed injectors too.
  16. The Following 4 Users Say Thank You to MudRunnerTD For This Useful Post:
    AB (31st July 2018), MB (31st July 2018), mudski (31st July 2018), Rossco (31st July 2018)
  17. #419
    324 Post(s)
    Thank god for @matfew and @Rossco ! Legends!!
    Intake manifold came out too.
  18. The Following 6 Users Say Thank You to MudRunnerTD For This Useful Post:
    AB (31st July 2018), Clunk (6th August 2018), MB (31st July 2018), PeeBee (31st July 2018), Rossco (31st July 2018), Winnie (31st July 2018)
  19. #420
    324 Post(s)
    So a few weekends ago i fitted the 4" snorkel and airbox. I cant remember if i posted it here? If i didnt i will add some pics.
    So intake side to turbo i stayed with 4" as far as i could. Its tight but im bloody stoked!!!
    Intake side i have fitted a 3" intercooler so have gone 76mm from turbo all the way to the intake. Damn it got busy!!!
    And how good does this look!!!!
    Late. I mean LATE Sunday night after something like 20 hours or more on the car for the weekend i lifted the bar back 9n to fit and Farrrk Meeee Drunk!! She aint gunna go back on!!!! No Farrkkking Way!!! Cooked i was
    See that bit ^^^^^^^^
    Yeah it supposed to go there vvvvvv
    Mutha farka!!!! Gutted.
    My wife had to knock back a shift at work and i had to fix it monday night
    Flipped the IC upside down and bought another couple of elbows and we are done.
    So bled the fuel injectors and bled the cooling and took it for a test run. Felt great but as expected the Clutch would not hold 3rd and was barely getting through 2nd. We will lump along for a week and get it sorted.
    I called Brett at 4wdObsession in Melton and booked a Clutch and tune for Today.
  20. The Following 3 Users Say Thank You to MudRunnerTD For This Useful Post:
    AB (31st July 2018), mudski (31st July 2018), Rossco (31st July 2018)
