Page 43 of 64 FirstFirst ... 33414243444553 ... LastLast
Results 421 to 430 of 634
Thread: Turbo Upgrades for the GUIV TD42Ti
  1. #421
    330 Post(s)
    So weekend just gone i had to refit the winch and re ran Ll the wiring and changed everything out to 70mm/sq. I also had a gigglepin Solenoid ready to go so took the opportunity to fit that into a permanant place in preparation of a himount i might have in the shed waiting a rebuild.
    I also ran the airline and wiring for the front airlocker i added a couple of weeks ago and wired into the mounted compressor in the back drawer wing. Switches also mounted in the dash (no pics sorry gents)
    192 Post(s)
    She's turning into a beast Daz, love the front mount engine bay looks heaps neater. .
  4. The Following User Says Thank You to Rossco For This Useful Post:
    MudRunnerTD (31st July 2018)
  5. #423
    330 Post(s)
    And today is the day. Brand new Terrain Tamer Excedy Tuff Clutch
    On the rollers. They we te e not prepared to do a pre tune roll because of the big fuel big boost he didnt want to risk damage which i appreciated.
    Roll off
    176rwkw.
    550nm Torque
    AF of 21
    Max EGT of 550.
    Speaking with the Tuner tonight and he compared the result to a UFI 18g but with a better AF ratio and lower boost. He was very please.
    When it was tuned by deiseltec Andy re removed the boost controller ans tuned the boost off the Actuator which he set at 27psi. 4wdObsession didnt want to change that setting so gave me a safe tune with what i presented.
    Roll On Power is kind of crazy in 5th and plenty of punch in every gear.
    Very happy. Clutch feels weird but once im used to that I'll be stoked.
  6. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    AB (31st July 2018), PeeBee (31st July 2018)
  7. #424
    581 Post(s)
    Keen for a drive of the beast at Licola mate lol
  8. The Following User Says Thank You to AB For This Useful Post:
  9. #425
    194 Post(s)
    Darren, great install. Word of caution though, from bitter experience with the silicone bends on intercooler circuits, and bearing in mind my boosts were a lot less than yours - those elbows are going to give you grief. The bends get hot and they slip from under the clamps. I see you have gone with the heavy duty bolted units, but. I found the only way to retain the silicone bends was to 'cocky spatter build up ridge' like a furl, so the hose clamp could clamp against a ridge and not allow the hose to slip. To rectify mine after a heap of trouble and twice coming home with leaking pipes on a 2.8TD - not fun - I converted the system to SS elbows and kept the joiners on the straight sections where they don't see the change of direction forces in play. Just my 2c observation.
  11. #426
    330 Post(s)
    Yeah cheers Phil. I had a fair bit of trouble blowing IC hoses off with the factory top mount so i know what you mean. I have tried to use the good quality clamps everywhere although i did run out and had to tax a couple from other tasks which i might swap out. Hot summer day and long beach run will test it out for sure. Thanks for the comment mate, ill keep an eye on it.
  12. The Following User Says Thank You to MudRunnerTD For This Useful Post:
  13. #427
    194 Post(s)
    Down the track after you have had some fun, I think it would not take much effort to replicate the compound bends with welded elements, using a stack of 90's etc. Install looks very sweet. Congrats.
  14. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    MudRunnerTD (31st July 2018), Rossco (31st July 2018)
  15. #428
    330 Post(s)
    Here are a couple of pics of the Snorkel fit up. I scored a second hand Radius Fab snork and airbox for a great price i could bot pass up.
    Came up a treat.
    Ok Snork pics
    Yes it was Real!!!!!
  16. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    mudski (1st August 2018), Rossco (1st August 2018)
  17. #429
    330 Post(s)
    Now my snork which i fitted the day before i saw this and thought id done ok but that bloke was next level!!!!
    This bolt was a bastard!!!!!!!
    No guts no glory!!
    Gained 5psi and a Growl of intake induction noise!!! Sik
  18. The Following 4 Users Say Thank You to MudRunnerTD For This Useful Post:
    Avo (1st August 2018), PeeBee (31st July 2018), Reddave (1st August 2018), Rossco (1st August 2018)
  19. #430
    Seen this on the weekend, looks pretty nice. Looks different in person though, especially this spot
  20. The Following 6 Users Say Thank You to rusty_nail For This Useful Post:
    AB (7th August 2018), Maxhead (7th August 2018), MudRunnerTD (6th August 2018), mudski (6th August 2018), Rossco (6th August 2018), Winnie (6th August 2018)
