4th November 2016, 11:14 AM
Sounds like the crank angle sensor is playing up when it gets hot. This will also affect the tacho.
Was there any fault codes?
When it plays up you can try pouring cold water over the crank angel sensor (front of the engine just above crankshaft pulley) and see if that helps.
dom14 (5th November 2016)
4th November 2016 11:14 AM
5th November 2016, 04:07 PM
Yendor
Now you're talking! Where have you been?
The Following User Says Thank You to dom14 For This Useful Post:
Yendor (18th November 2016)
7th November 2016, 03:21 PM
Yendor
Was there any fault codes?.
Was told if engine light doesn't keep flashing after starting that it did not keep the code, as i'm a newbie I have no idea if this is true and only had the car for 2 weeks now so haven't added any additions like scan gauge or modified it as yet.
7th November 2016, 03:26 PM
On a different note, what mods should I get done first? probably doing up to med - cruising to start of with. Winch, Lockers, lift or bigger tyres? bank balance wont accommodate all at once.
7th November 2016, 03:39 PM
Pj-14
IMHO not much point in putting larger tyres without lift - they may catch on body . The idea is to lift so that the tyre s can move more and larger ones can fit. (thats pretty basic,there is more to it than that). Winch - shouldn't need that too often, Lockers - really want the biggers tyres and lift before putting lockers in. So lift first, possibly the best for the wallet and can improve your ingress and egress angles without any other mods. The others can follow as you get the finances.
The Following 2 Users Say Thank You to 4bye4 For This Useful Post:
dom14 (8th November 2016), Pj-14 (7th November 2016)
18th November 2016, 12:38 AM
Pj-14
Not true. It will still be logged as a history code.
The Following 2 Users Say Thank You to Yendor For This Useful Post:
dom14 (22nd November 2016), Pj-14 (19th November 2016)
22nd November 2016, 10:31 AM
#17
mmm so the Diesal has a crank angle sensor ?
Yendor
Well that might help me with my 4.2 Diesel . my Tacho plays up and have not been able to find the problem .
22nd November 2016, 12:11 PM
#18
Replaced crank sensor as it seemed to be leaking some oil & had erratic movement as seems to be the issue here .
tacho still has the problem, not all the time, you just see it jump upwards occasionally no better no worse than before hand
Putt it down to some dust in the tacho mechanism.
I have also seen this in my R32GTR.
Was able to semi pull GTR tacho apart clean with maff cleaner , issue half as bad/often.
Note --Carby clean can have a dry lube additive, not recommend on a sensor as you will coat it,
Maf cleaner might be a better idea.
But thread vehicle is much newer,more electronics than my TD which has no computer at all, GTR had 4 computers and same issue, but never tried to shut down or throw a code.
IF IT'S NOT A NISSAN.
THEN IT'S A COMPROMISE
22nd November 2016, 12:59 PM
#19
Tip12345
The 4.2TD are different. What year model is it?. Is yours the TDI?
23rd November 2016, 08:23 AM
#20
Mine is A 2005 td inter-cooled .. I have been looking for a Description of the injection system . It has one injector with A wire on it ! the Tacho is intermittent thanks to all
