Results 1 to 5 of 5
Thread: Measuring a lift is it 3" or 4" ?
    Oct 2016
    Theebine, QLD, Australia
    Hey all I am only new to this forum so sorry if I am double posting or not using the correct section, I have recently purchased a TD42 SWB Maverick, (I know it's a nissan not a ford) just wondering how I determine the height of the suspension lift it has in it (the previous owner was unsure) I am in the market for some Big 0 dropped radius arms but first need to confirm the lift height, do I simply park on a level surface with the same psi in all tyres and measure from the ground to the guard and compare to stock height ? what is stock height ? cheers for all info, any help greatly appreciated does it affect the measurement having 33"X12.5 tyres on there ??
    If you can find the part numbers stamped/etched into the springs, then you could search google
    Oct 2016
    I will have a look mate I should be able to as I can see the bit where it says king springs, thank you for the advice.
    Oct 2016
    coils part number kdfr-42sp3 (front) and kdfr-43sp3 (rear) I believe this to be a 3" lift
    472 Post(s)
    G'day Brian, There is a weight/height stop within 30 clicks of a little country town called Maaansfield ! Full techo blokes; All jokes aside, please do keep your shorty down 'low' & 'slow' old mate, been bitten meeself :-) !
    Edit: Sorry Brian, just realised you're in QLD mate nowhere near our VIC high country boys in blue with their bent tape measures! Safe travels!!
  7. The Following User Says Thank You to MB For This Useful Post:
    mudski (24th October 2016)
