Page 5 of 5 FirstFirst ... 345
Results 41 to 48 of 48
Thread: School me on DC/DC chargers and systems
  1. #41
    Dec 2017
    I like the red covers, may have to do the same
    Patrol Guru 0-TJ-0's Avatar
    Jan 2017
    South Australia
    11 Post(s)
    I believe it would still have a voltage cut off... Regardless of what the ignition wire is doing.... I'd have to have a look in the manual to confirm.
    11.8 cut in 11.4 cut out.
    What mine says anyway. Can't see too many batteries ever getting down that low in purpose so it will be pretty well always on if you connect that wire.
    Nice neat setup by the way.
  4. #43
    Dec 2017
    Had a interesting issue on the weekend. First camping trip in installing the ctek d250SE . Been working ok as cars been parked with solar connected to maintain batteries due to travel restrictions. As it’s a 97 GQ and a 105 amp AGM i connected the black wire on the smart alt to earth . Well it just flashed the current saving mode (green light left side lower) . After much checking I disconnected that black wire (earth) and it started working. Connected the earth back and nothing. Anyone had this issue ?
  5. #44
    Jan 2017
    South Australia
    11 Post(s)
    (edit because I got it wrong)
    Are you talking about the black agm wire or the red smart alternator wire?
    Is it charging okay off solar? But not off the alternator?
  6. #45
    Dec 2017
    Morning, the black wire in the same sheath as the smart alt red wire. No doesn’t want to work when in AGM (earthed) but does when in lead acid . Only thing was done prior to leaving was I connected a 240v battery charger to car night before when I turned 2 fridges on .
  7. #46
    Jan 2017
    South Australia
    11 Post(s)
    Yeah can't help sorry, if it was all working okay and now it's not it must be a fault. Either in the wiring or the unit.
    I've charged mine with a 240v charger plenty of times with no issue.
  8. #47
    Dec 2017
    Thanks for the feed back. Not a lot of info out their .
  9. #48
    Dec 2017
    Update, black sensor wire (earth for Agm ) was not a good earth . Was earthed to body where a existing wiring harness earth was . CTEK unit needs a perfect earth (direct battery earth). Have had no issues since .
  10. The Following 4 Users Say Thank You to Patricapatrol For This Useful Post:
    0-TJ-0 (7th July 2020), Cremulator (7th July 2020), MudRunnerTD (6th July 2020), PeeBee (7th July 2020)
