12th October 2016, 09:09 PM
Mobil 80W90 oil OK for GQ?
Hi
I have a 4ltr container of Mobil HD 80W 90 oil. Does this suit a 4.2 diesel GQ? Presumably for diff or g'box. Only asking as it was bought a few years ago for another vehicle which I no longer have. The only use I would have for this oil would be to take on long off-road adventures for emergency use. Not wanting to damage anything of course.
What do you think?
12th October 2016 09:09 PM
12th October 2016, 09:12 PM
What spec is the Oil? If it is a GL-4 spec then you can use it in your gearbox as well as transfer case and front diff. If its a Gl-5 then can only really go in the transfer case or front diff.
The Following User Says Thank You to nissannewby For This Useful Post:
MudRunnerTD (12th October 2016)
12th October 2016, 10:29 PM
nissannewby
I thought the transfer case takes auto tranny oil?!
Or does it depend on the year of the transfer case?
12th October 2016, 10:33 PM
dom14
Can take either.
dom14 (14th October 2016)
13th October 2016, 10:20 AM
Looks like API-GL.5. Label also says suitable where SAE 80W-90 EP us specified.
I'll assume then that front diff and transfer case is ok. Also just to clarify car is 1991 build.
So if I got some GL4 would that be a better option for emergency situation?
What then about rear diff with the LSD?
14th October 2016, 10:29 AM
monty
LSD diff oil. You can't use normal diff/gear oil on LSDs.
16th October 2016, 10:06 PM
#8
GL5 will attack the brass syncros in the gearbox.
"Can't" is a dirty 4 letter word.
Best way to deal with a "Can't" is to chop off the "t" and brew it in boiled water for a few minutes.
Sip on the "t", and consider what you've got left to work with
The Following User Says Thank You to Arfa Brayne For This Useful Post:
dom14 (19th October 2016)
