6th October 2016, 09:08 PM
auxiliary battery charging
Hi guys,
In the process of installing dual battery set up in the trol.
Got an ARB battery tray, fitted after turning into a magician.
Got a 100ah deep cycle which covers my needs.
Now Starting with a dumb arse Q: where is the best place to earth auxiliary batt' on a ZD30.
The next bit is doing my head in, isolator vs charger.
Will an isolator (Redarc sbi12d) be sufficient to keep a deep cycle charged or do I need to go for a charger.
Then it comes down to Redarc vs projecta, or are there other brands that people recommend?
What are the pros and cons, is one better than the other. What are you all running to keep your deep cycles charged? Any tips or advice will be much appreciated
Cheers guys
Pete
6th October 2016 09:08 PM
7th October 2016, 12:13 AM
I am he, fear me
IMHO an Aux in teh engine bay doesn't need a 'charger'.
The voltage drop from the Alt to the Aux is bugger all so an Isolator can charge much quicker than a 'charger'.
You only need the SBI12D if you are charging both ways (have solar or whatever hooked to the aux) otherwise an SBI12 is sufficient
Brand is kinda up to the individual but Redarc pretty much set the standard for the non-programmable jobbies
The Following 2 Users Say Thank You to the evil twin For This Useful Post:
blocko05 (13th October 2016), wildgu6 (7th October 2016)
7th October 2016, 01:23 AM
the evil twin
Cheers for that ET, mates with limited knowledge of elec's have been telling me I need a charger for a deep cycle, which kinda scattered my way of thinking. Was set on sbi12 or 12d for external charging until then, but you have cleared that up for me.
Cheers mate 👍
7th October 2016, 09:38 AM
Missing in Action
wildgu6
Using a bolt on top of the alternator for mine.
The Following 2 Users Say Thank You to VK2FMIA For This Useful Post:
wildgu6 (7th October 2016), Yeti's Beast (19th December 2018)
7th October 2016, 09:10 PM
VK2FMIA
Cheers bud, was looking at somewhere around there, didn't want to go to the body, risk of bad earth.
