Results 1 to 10 of 14
Thread: How to drive the RD28T
    Oct 2016
    It may seem like an obvious question but this is my first time owning a diesel (GU rd28td) and I wanted some input on how people drive theirs in terms of rev ranges and whether anyones fitted an ultragauge or similar product to test consumption across rev range?
    The rd28td seems to go goes against what I'd heard most diesels have a strength in, being low down torque, as it feels tremendously weak before 2000rpm lol
    Couldn't find much with a search but I'm hoping there's some proud 2.8 drivers willing to share their driving habits.
    194 Post(s)
    Crispy, I bought a new gq td2.8t in 1997 and have just swapped the engine out. I can offer my thoughts after looking after one since then. They are a horribly torque-less engine until you get them to 3000rpm then they have a moderate chance of holding speed on a hill. Mine was so poor I ended up putting a marks 85% reduction gear for low range and it transformed it off-road. Biggest thing was getting a k&n air filter and keeping it clean as engine will bog down if restricted. I also fitted a snorkel and safari inter cooler and picked up some gains there. Keep on top of fuel filters and oil changes. Keep the overall weight of the vehicle down as the fuel consumption will rise badly. When the ambient temps rise over say 35 degC lower your speed on the open road and watch the temp gauge as these motors are renowned for overheating, but saying that I only ever had 1 day that left me feeling like the engine was running on 3 cylinders and that was my own stupidity for pushing too hard in 44 deg C. Mine was a solid engine with only 120,000 on it and it was very reliable and trouble free. I changed the engine because I wanted more hp and torque, plus will be looking to tow a camper and I didn't think the 2.8 was what I really needed. Hope this helps.
    PHIL
    Oct 2016
    Thanks Phil this is the kind of stuff I was hoping to hear about. In your daily driving did you regularly rev over 3000rpm? I know where the red is on the tacho but I haven't been game to take it right out there yet haha.
    Where has your 2.8 ended up if you don't mind me asking? Thanks for the heads up re. over heating too.
    194 Post(s)
    Crimpy, yes regularly up near the start of the red line, more in first or second then eased off. The revs rise of course also for 4th to 3rd drop downs. The engine does like to rev and is comfortable doing that. I did an engine upgrade to a Brunswick Diesel 6.5 V8 Optimiser crate motor - non turbo. I am waiting for it to leave Perth now. I traded my engine in with them and got 4K for it. It was in perfect condition and well maintained. I could only really limp it around if it was totally empty and when full needed a fair share of clutch slip to get it of the mark. The motor will start retarding when the revs get too high, and I think a lot of young guys give these motors a flogging and get a shorter life accordingly.
    Oct 2016
    Mate that is quite an upgrade in capacity! Ah good stuff. Did you fit any gauges to your previous setup Phil? And you never had any problem with the k and n filter or keeping it isolated from external environment?
    194 Post(s)
    Quote Originally Posted by Crimpy View Post
    I fitted a boost gauge off the inlet manifold, an EGT off the exhaust post turbo, ran two aux temperature probes off the radiator to get a real understanding of the coolant temps, digital volt meters on main and aux batteries, but all this gear was dash located, not in a pillar pod. The pods look good but I wonder what sort of distraction or annoyance they might become with the glow right at your eye level?
    I had an exhaust upgrade in the pipeline before biting the bullet on the new engine. I see a number of guys upgrade in the area of 2.5 - 3" with good results.
    The K&N was located inside the safari Snorkle airbox - the 2.8 snorkle comes with its own plastic airbox fitted on passenger side. The thing to watch is the air inlet from the snorkle is on the side of the filter housing, and tends to build up locally with all the bugs, dirt leaves etc that fly down the snorkle. The local impact zone can clog up quickly, however the weave of the K&N still gives great efficiency, to a point - again its another maintenance focus point. The filter was purchased off ebay - around $120 from memory - then you have the service kit at circa $35?. I believe they are worthwhile for sure, as a factory element is around the $35 mark and if you are doing big klm's you will chew thru them. Also the factory ones dont breath well when they get moist and the dirt turns to a fine mud - the K&N must lose efficiency also under these conditions but didn't seem as severe.
  8. #7
    Oct 2016
    Champion, that's some top notch info thanks mate. It came with a snorkel fitted so appreciate all the knowledge!
  9. #8
    Oct 2016
    PHIL
    Were you happy with the 85% reduction gears, what made you go 85%?
  10. #9
    Advanced gbab01's Avatar
    Adelaide
    Hi Crimpy.
    I had a 2.8TD GU for about 5 years now. They are a quirky motor no doubt about that but once you work them out I think they are good motor. Yes, they are poor down low for torque. You will need to ride the clutch on a slope to get going. They can take a bit of forethought as you drive in to a sloping intersection etc. Revving over 3000 is no problem and you should find that third hear pulls all day. I have towed with mine, a small van. Don't tow in 5th that's a recipe for disaster I am told. Fuel consumption could be better but think about what it's pulling around. On the up side I have found that consumption of fuel towing is not much different than general use around the city so it's fairly predictable. I have a boost gauge and a EGT which I have found worthwhile as the can get warm going up hill. Off road in low range I have found it to be excellent. It will get you where you want to go. I recently had to replace my MAF sensor as I found the power was really down. It made a huge difference (recon unit eBay $100). There is plenty of info around on how to check they are working properly. The one thing I would really push home to you is to get the oil and oil filter changed every 5000 k's. Overall once you have worked it out I think you will find it serves you well.
  11. #10
    Oct 2016
    Thanks mate both the boost and EGT are on the list; don't seem too expensive and both worth while. Where abouts did you install yours?
    Have you got the standard exhaust on yours? Curious to know how that impacted temps if you have upgraded to 2.5 or 3 inch.
