Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Broken Shocker
    Patrol God mudnut's Avatar
    SW Vic.
    80 Post(s)
    No, the only marks are from the broken pieces.
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    The spacer wouldn't make bugger all difference in the grand scheme of things..
    Meassure the length you have from shock mount rod to rod, then meassure your bump stop to axle..
    Subtract the bump gap from the shock length and that's the fully closed length.
    Get a shock 10mm shorter for safety.
  4. The Following User Says Thank You to BigRAWesty For This Useful Post:
    mudnut (21st September 2016)
  5. #13
    Enjoying the trips macca's Avatar
    Oct 2010
    Old Bar, NSW
    13 Post(s)
    You have not allowed for the compression of the bump stop, a few tonnes compressing the suspension in a quick movement will compress a 120mm (rear on a leafy ute) bump stop to half that if not less, and that's only guessing.
    Any suspension mod that allows the shock to fully close before the suspension does is going to fail, as is the other way if the shock is not long enough for reasonable travel and gets torn apart by over extending.
    The Simpson Desert is notorious for destroying suspension because of the extremely rough terrain causing the suspension to travel its full range all the time.
    Macca
  6. The Following User Says Thank You to macca For This Useful Post:
  7. #14
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    Quote Originally Posted by macca View Post
    Yea sorry I did mean the base..
    But what bump do you guys run in the leaf utes.
    Wagon fronts compress about 120mm. The coil rears compres about 30mm I think.m
    Oct 2010
    Old Bar, NSW
    13 Post(s)
    Its a rubber wedge 120mm from the tip to the chassis, fairly solid to take the hits I guess.
    Being wedge shaped it would compress progressively, but I'll leave that to smarter minds to explain the science!
    Macca
