12th September 2016, 04:13 PM
Patrol Guru
Silicone vacuum hose
Has anyone used silicone vacuum lines and how do they compare to the rubber lines. i noticed on the weeken that my boost was very low (about 6psi) and I tracked the problem down to the vacuum lines connecting the dawes valve. They had gone soft and were losing vacuum. Trimmed the ends off and reconnected, boost back to normal.
12th September 2016 04:13 PM
13th September 2016, 05:15 PM
I found the same and fitted 1/8 high pressure polyethylene pipe.
Silicone was just to soft and flexible for the small size.
