26th September 2016, 07:19 PM
front wheel bearings
Today i bought some front wheel bearings for the patrol. (1998 G.U. station wagon) Kit came with two seals, but the online manual image has only one as far as i can see. can anyone clarify please??
26th September 2016 07:19 PM
26th September 2016, 07:32 PM
Patrol Guru
You might have got the axel seals as well small seal about 30 mm diameter
26th September 2016, 07:45 PM
No, the big one is about 88 mm and the other one is about 71mm.
26th September 2016, 10:11 PM
Moderator
Have a look here mate there is an exploded diagram at the start and everything you need to know is there
http://www.nissanpatrol.com.au/forum...Rebuild-Thread
Check out my Toy -->
Rogue Dung Beetle
27th September 2016, 02:24 PM
+1 for the guide linked in the post above.
I just did my front bearings and it is a great guide.
There is definitely 2 big grease seals. 1 goes on the back of the disc rotor ( I think that's the larger one), and the other goes on the kuckle spindle. It will be more obvious when you pull it all apart.
Adam
The Following User Says Thank You to thebrod For This Useful Post:
threedogs (27th September 2016)
27th September 2016, 07:36 PM
Thanks everybody. After reading the rebuild thread it looks much clearer. I now feel fairly confident to do my bearings, thanks again.
27th September 2016, 08:06 PM
