Results 11 to 20 of 24
Thread: Interesting read - doesn't mince words about ZD30's
    Advanced AGman's Avatar
    Mar 2016
    Agree. But does anyone believe Mr Nissan outsources this procedure for interval servicing of ZD30's? C'mon they're at the limit actually changing filters.
    I actually agree with you there. No disrespect to macca, but I do think the author is a bit sensationalist in the article in regards to some of his comments.
    "We checked with a development engineer from General Motors about the need for catch cans on non-competition vehicles and he told me that if GM believed for one second that a relatively cheap part attached to the engine would improve reliability, limit warranty claims and reduce replacement costs, it would have been included in the PCV system"
    I think it's a bit naive of him to accept this comment from a GM spokesperson. Experience has proven over and over again that most manufacturers will not spend $10 per vehicle to improve the longevity of it. My experience is the opposite, if they know a component will make a vehicle fail a few years out of warranty they will stick with it. I think he might be a bit too close to the manufacturers, they come down hard on dissent these days.
    I am an engineer that's been involved in development projects and the bean counters and marketing wonks own the projects, you just build it cheap as possible and tow the line or lose your job.
    I don't think he has a complete understanding of the EGR issues either. All the manufacturers are having these problems with their CRD engines, not just the ones he listed. Its not a carbon issue in the strictest sense of the word...its recirculated soot from the combustion process mixing with recirculated oil fumes from the crankcase, remove one or both of these things that shouldn't be in the inlet tract and you fix the problem.
  2. The Following 4 Users Say Thank You to AGman For This Useful Post:
    mudski (7th September 2016), Rock Trol (7th September 2016), Sir Roofy (7th September 2016), taslucas (7th September 2016)
    Patrol Guru Rock Trol's Avatar
    Mar 2013
    NE Melbourne
    I think the point Allan was making in the article is that the EGR system needs to be serviced regularly (every 40-60,000 km????). This could be a chemical clean such as the walnut shell treatment, EGR cleaner or taking the manifold off and manually cleaning. This becomes another service cost that I think most people wouldn't want to pay on a regular basis and are not aware off when buying a modern diesel.
    As AGman said if you take away the soot, oil mist or both then the problem does not occur. The engine emissions however are not as clean
  5. #13
    Mar 2016
    Quote Originally Posted by Rock Trol View Post
    You are probably right, but he should come out and say it rather than this condescending article that assumes anyone who lifts the bonnet of their 4WD is a moron and has no right to do it.
  6. The Following User Says Thank You to AGman For This Useful Post:
  7. #14
    Mar 2013
    NE Melbourne
    Quote Originally Posted by AGman View Post
    You are right in that he puts his faith in the manufacturers designing a system that will meet emissions standards and last with minimal maintenance. Some engines may do this, others may not be designed as well. I think if manufacturers can get them to last the warranty period then that will be good enough for them. Not so much for us.
    The other thing he points out is that if you remap or chip an engine it is likely to increase the crank case pressure so you get more blow by. He strongly recommends against this. The problem is that most people will seek to increase power, especially if the engine is underpowered for the weight of the car. A lot of diesel 4WD's do OK out of the show room but as soon as you add the weight in the form of accessories they no longer cope. This is what has happened in my case. I did all the touring mods and then found the engine (ZD30 CRD) couldn't cope which put me on the expensive path of searching for more power.
    It's almost enough to send a guy back to petrol engines.
  8. #15
    462 Post(s)
    Never!!!!
  9. #16
    May 2016
    lower west victoria
    30 Post(s)
    I felt like this when I read this article, I actually didn't read the entire article as I didn't agree with the parts I had already read.
    I don't believe manufacturers would fit items that would help improve longevity. They want to produce vehicles that are legal and can be sold as easily as possible. To me this means, if it's good enough to comply with ADRs (I'm no expert here) and federal & state requirements that's as far as they'll go with it.
    And all this scare mongering about this isn't legal and that's not legal, people do that to make themselves look authoritive and thereby acquire a a false sense of power that makes them feel that they can tell people off. I get tired of people telling me "you can't do that, it's illegal" mind your own business.
  10. The Following User Says Thank You to 10G For This Useful Post:
    Winnie (8th September 2016)
  11. #17
    Ballarat, Vic
    174 Post(s)
    Often a case of shooting the messenger.
    I’m not taking a position on what Allan Whiting has written, but I do think you do some folk a disservice by taking the view you have expressed.
    Simply telling folk that something is illegal only provides info, readers can make up their own mind about whether they will choose to comply with the law. It is quite common for folk to decide to do mods on the basis of ‘my mate did it’ without ever considering the legality. We need to be able to make fully informed decisions if for no other reason than knowing the level of risk/potential implications. Eg. the possibility of having an insurance claim denied because a vehicle is legally unroadworthy.
    Eg.
    Not so long back I posted a suggestion that it may be unwise to ‘advertise’ here on the forum that a poster had fitted an EGR blocking plate. The suggestion was derided by a few & subsequently ignored by some, which of course was their prerogative. All I did was suggest that posting that they had done this may not be in their own interests. No attempt to ‘tell people off’ or to ‘look authoritative’ but you could have thought otherwise based upon some responses. It’s not hard to write about it in a manner which doesn’t leave you open to unwanted consequences. Agreed some folk don’t like being ‘told’ anything, but some could also try to recognise that sharing info is different to telling people what to do. I can’t help thinking that sometimes chips on shoulders act as filters to well meant actions.
  12. The Following 2 Users Say Thank You to Cuppa For This Useful Post:
    mudski (8th September 2016), Touses (8th September 2016)
  13. #18
    May 2016
    lower west victoria
    30 Post(s)
    Eg.
    I absolutely 100% agree with all that Cuppa. My 'telling people off' comment wasn't aimed at anyone, sorry if made you feel uneasy or anything.
    I think I'm just fed up living in a PC (politically correct) world.
  14. #19
    Hardcore
    central coast nsw
    Not talking down to anyone, just think sometimes we forget or want to forget, as it may cost $$ or hurt our feelings
    Engineers have alot of problems to deal with--
    The bean counters.
    keep design time to a minimum.
    keep production time down.
    Re use existing parts if available.
    Deal with the ever changing emission rules.
    keep the actual emission control device cost down.
    And why build something that lasts a long time less profit in that.
    Then there's the huge amount of competition to deal with making cars/trucks.
    Now we see small changes at a time, to re-coupe "All" design and build costs.
    even at times it doesn't realy work, we can update that next year and call it a new model!.
    A sticky situation for sure, none of us grown ups like being told you can't do something.
    We expect laws to protect us against the bad things , but something we can't see, has no effect to us personally,or then and there is --she'll be right mate.
    Part the problem we're constantly being told by cleaver marketers "You can have this Now", but we usually forget, it is always at a cost one way or the other.
    IF IT'S NOT A NISSAN.
    THEN IT'S A COMPROMISE
  15. The Following User Says Thank You to Robo For This Useful Post:
    4bye4 (8th September 2016)
  16. #20
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    Quote Originally Posted by Robo View Post
    The bean counters.
    And then add in hundreds of different end users and conditions they are used in. Why do some engines have a fit and go into limp mode when you open the bonnet with an EGR Blocking plate in your hand while others dont even need an adjustment when they have every mod available fitted. Every engine is different even though it is of the same design and specification. We expect our design engineers to produce a "one size fits all" with all the constraints mentioned above, plus it must work forever and be economical to maintain and run. The article is well written and is a good read, but anyone who seeks to explain the grenade issue by linking it to one cause is in my opinion treading on very dangerous ground.
